‘18 S560 - missing short (4”?) piece of grill trim.
Can anyone offer a reasonable suggestion on finding a single piece, short of digging around in a bone yard?
See post #517 in this thread (https://mbworld.org/forums/s-class-w...ml#post8561315)
Thanks a million!
Thanks to others here, the part # is MERCEDES X222 S-CLASS W222 X222 Cap 22288502269040.
Just make certain if you buy on the open market, your dealer agreed to install and calibrate the part.
I bought an aftermarket part from E Europe but don’t know what the dealer will agree to yet.
- I ordered 222-885-02-26-9040, I do have the 360 camera, this is the door, with the trim piece attached.
- The install wasn’t too bad, remove the four 10mm bolts across the top of the grill, and then pull the grill forwards.
- There are three clips across the top and two on the bottom that hold it in place after that. I gently pried them out on the top, and pulled the grill out at the bottom
- Detach all of the electrical connectors, I had 3.
- Place the grill face down on something soft (a towel or sheet)
- There are five torx screws holding the camera assembly in place, take them all out.
- See picture below
- Push the camera door so that it’s wide open, and pull the camera out.
- The door has a spring on it, take note of where it is!
- Really, take note/a picture of how it's installed
- Unclip the door, and your ready to go in reverse.
- Putting the spring back on the door was a pain, but after that it went quickly.
- Go to fridge
- Remove adult beverage
- Open adult beverage
- Sit back and enjoy!
That was it - took maybe 5-6 minutes to pry it off with his pocket knife, and three seconds to insert it. Perfect fit. The only tools je used were his knife blade and his fingers. No cost.
- See picture below
- Go to fridge
I noticed mine is missing the chrome trip on the camera door too, after a car wash drying. I see that you replaced the entire camera door. Is their any reason that I should not just simply order only the chrome trim piece and install it simply without removing anything, instead of ordering the entire camera door that needs removal of the entire grill ? See below. Do you recommend I apply glue to make sure it does not fall of again?
https://www.ebay.com/itm/39447429301...3ABFBMyt7kkOJh
Also the part description says: "Validity: With (model year 2014, model year 2015, model year 2016, or model year 2017) and 360 camera."
So it clearly says 360 camera for sure. Now the only concern I have is whether it also fits the door camera door for the facelift 2018+ or not !!!
Looking at the trim piece in photos, it seems similar for pre and post facelift, but i guess the inserts from behind may have difference geometry which I guess that your bodyshop friend had to do... ?
Edit: reading through all your comments, it looks like what you purchased is the full door cover for the facelift, and then you removed the chrome piece. What I am doing is buying just the chrome trim itself for $20, but then hopping that pre-facelift and post-facelift have the same chrome piece geometry. I also thought about ordering the entire door peice like you did for 100 USD but then found the chrome piece alone for $20 (risk is that it is for pre-facelift) and then will try to see if the trim piece will match the facelift door camera trim.
With my repair, no scuffing, no glue.
On the back of the chrome piece there were two small hook-like protrusions. It simply pushed into place.
