S-Class (W222) 2014-2020
how to tell if transmission oil has been done?
Old Jun 27, 2022 | 03:55 PM
flohmann1's Avatar
none yet
I'm curious if there's a way to confirm whether or not the transmission oil has been replaced using the service menus? My 2015 S550 came to me with 65k miles on it, with dealer service records up to 45k miles. So there's an 18-month gap in records, and I'm not sure whether the recommended 60k transmission oil replacement was done. Is this something that ASSYST Plus tracks?
Old Jun 27, 2022 | 05:52 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
There is a big debate as to whether a transmission flush is necessary at all. I've been told that transmissions react negatively upon a flush.
Old Jun 27, 2022 | 06:18 PM
flohmann1's Avatar
none yet
My understanding is that while there is lots of advice against a *flush*, there is consensus that the fluid should be *changed* at 60k (as recommended by MB in the maintenance schedule)?
Old Jun 27, 2022 | 11:33 PM
Jim Ma's Avatar
S 550, S65 Coupe
I would just change it. Probably wasn't done as the previous owner defered it as he probably knew he was getting out of it soon. Better to be safe than sorry.
Old Jun 28, 2022 | 05:34 AM
MB221's Avatar
W222 400D 4-matic
Had the same question as you did. Mine didnt had any servicerecords in the DSB nor is there any written booklet anymore since erverything is digitally recorded. So how to tell if the oil is changed? There's only on way and thats to remove the transmissionpan and look at the date stamped in the filter. It states the manufacturingdate and hence you can "somewhat" conclude if its been done cause whenever changing the oil, you need to change the filter.
Personally i dont see any reason not to change transmissionfluid after 50-100k miles. Any oil loses its capabilaties after use. Mine started shifting worse after a oilchange but that was caused by the dealer NOT resetting some settings AFTER changing the fluid. This resetting is MANDETORY by MB, but they forgot of just didnt give no F@#$. They didnt even record the service in the DSB, so therefor i had the same question as TS. After checking the filterdate, changing the oil for the second time and resetting some adaptationvalues the shifting noticely improved.
Old Jun 28, 2022 | 05:43 PM
vatakle's Avatar
s550
My 2016 has 11k miles on it. Considering its age, should I get the transmission oil changed? I am told by a Mercedes shop that there is no drain and fill of transmission oil just a complete service. Is that correct? Is it better to do it from dealer or from a independent Mercedes only shop considering it has 6 months factory warranty left? Thanks.
Old Jun 28, 2022 | 06:36 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
Leave it, unless you have been taking the car to race tracks.
Old Jun 28, 2022 | 09:28 PM
seamus2154's Avatar
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
I doubt it was done. Its an expensive dealer service, and many get out of it by trading before due. Also many owners don't even know to do it, and are only prompted by the dealer if ever. I have bought many used Mercedes and have only seen it done a few times in the service records. My current car was bought at 27K so it will be my doing probably next year. I would definitely do it. I have never seen the fluid look terrible at 50-60K but it is definitely used. I did the rear diff fluid, and it looked brand new coming out, so that was no rush either.
Old Jun 28, 2022 | 09:36 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
I had mine changed recently at 45K miles and the transmission feels noticeably better, fewer harsh downshifts. It was costly but I enjoy the car more now and glad I had it done.
Old Jun 29, 2022 | 10:33 AM
seamus2154's Avatar
Short answer no on transmission. BUT short trips, and low miles do require more frequent oil changes for different reasons. Your minimum oil change would be 1 year regardless of miles. Which means you should have had at least 6 oil changes already. Acids and moisture in your short trip oil are more detrimental than high miles.
Old Jun 29, 2022 | 02:55 PM
vatakle's Avatar
s550
Thanks. I asked because the transmission does feel jerky at times. Its not smooth. Yes, i do have frequent short trips (6-10 miles) a day. That was the reason why I ask for transmission oil change. But will skip it as don't feel the need for it. I did get the Service B done at Mercedes as soon as I bought it so oil change was done. The service writer was recommending to do a 6 year old service based on the age of the car but I skipped it as it has low miles.
Old Jun 29, 2022 | 05:12 PM
seamus2154's Avatar
With such low miles, and short trips, its kinda hard for your learning computer to adjust. The dealer can do a reset, and it will start a new learing pattern of your driving habits. There may also be an update? That may improve things. My 2016 is not perfect and can be a little jerky but its the hard downshift out of nowhere sometimes.
Old Jun 29, 2022 | 05:20 PM
vatakle's Avatar
s550
Thanks! I will check with the dealer. much appreciated!
sorry to hijack your post - OP.
