S-Class (W222) 2014-2020
Windshield Washer Pump
Old Nov 20, 2022 | 08:12 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Hi Team 222.
my windshield washer sprays no fluid and makes no noise when button is pressed.
Diagnostic on the C4 shows no issue.
hmmm any ideas?
replace pump?
Old Nov 20, 2022 | 09:11 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Yes, the most common issue is the tiny inlet filter holes are clogged. In my car the actual motor was also burned out, so I replaced both it and the filter.
Old Nov 20, 2022 | 11:09 PM
vinflouen's Avatar
I'm going to remove the tank and see what's happening.
MIne is probably clogged and burnt....
Old Nov 22, 2022 | 08:27 AM
autoluke's Avatar
2003 S430
WHERE IS THAT FILTER LOCATED ...CAN IT BE REMOVED ??
Old Nov 22, 2022 | 10:56 AM
The filter's actually just the little $2 grommet where the pump goes into the tank. You have to take the tank out though to get to it.
Someone recently did a really nice post with pictures showing how you do that. Quite easy once you see what to disconnect, move out of the way, etc.
Old Nov 22, 2022 | 02:45 PM
Merserybenze's Avatar
2022 AMG GT 53, 2020 Sl450. Did drive 2018 S450
My filter was clogged. I mixed an ounce of Clorox with a full tank of water. Left it overnight. Next day all the gunk in the filter was gone. Washer worked fine.
Old Nov 22, 2022 | 07:02 PM
vinflouen's Avatar
while it was clogged did you hear the pump at all?
Old Nov 22, 2022 | 07:10 PM
will_atl's Avatar
2020 S450 4Matic, 2022 GLS450 4Matic, 2015 C300
It was me! It is a relatively quick job, even to swap the pump wouldn’t take long. I would check for goop first.
https://mbworld.org/forums/s-class-w...gic-again.html
Old Nov 22, 2022 | 08:14 PM
Yes but hardly any water came out prior to Clorox clean. I was about to remove everything and clean filter. Tried this last resort and it worked.
Old Nov 22, 2022 | 08:31 PM
vinflouen's Avatar
Ok.
My pump is silent so it's gotta be.....
Old Nov 26, 2022 | 04:17 PM
vinflouen's Avatar
I did this today.
took about an hour.
I didn't disconnect any hoses or remove fender liner.
You have to remove the coolant tank and front part of the air intake
Old Nov 27, 2022 | 12:49 PM
will_atl's Avatar
Did you end up replacing the pump?
Old Nov 27, 2022 | 02:00 PM
vinflouen's Avatar
Yes, the pump was dead and there was scum in the filter rubber grommet.
So I washed everything out and put new pump, works like it should now..
if you hit the wash button on the turn column and hear no noise from the pump it's fried, replace pump.
I got mine for 40 something on Amazon.
Old Nov 28, 2022 | 05:23 PM
Nice going, you saved yourself a couple hundred dollars (my Indy shop wanted $250 for this job).
Good idea to thoroughly wash out the tank so it doesn't clog up again ;-)
Old Nov 28, 2022 | 09:32 PM
vinflouen's Avatar
Thank you much!!
My wife stopped bothering me about tinkering with things a long time ago...lol....I am a YOUTUBE/MBWORLD CERTIFIED MECHANIC/HVAC/PLUMBING/COOK/ELECTRICIAN/LANDSCAPER...ETC..
