Need a Replacement Rear Wheel
Have any of you upgraded your wheels and would be willing to sell a rear wheel? I am located in Dallas, TX if anyone is local.
Any online vendors you would recommend to pick up an OEM wheel used, refurbished, or new?
Thanks in advance for your help and pardon the dirty wheels it's been rainy lately.
Part # 22240105007X21 Charcol Gray
The rim shop I use has multiple dealerships dropping off their rims. I’ve seen Audi and Porsche and Lamborghini rims.
They are closed for the holiday. So I haven’t had a chance to speak with them about repairing my wheel. They also offer OEM and Remanufactured wheels with lots of options.
Have any of you done business with them?
https://wheelsamerica.com/?product_c...t_type=product
Took a look under the rear end of the car and only saw plastic covers.
Where is the best place to lift the rear of the car so I can place jack stands at the rear jack points?
Remember any vehicle with air suspension can deflate when a wheel is lifted. Just be aware that you may need an extra low clearance jack when the suspension has deflated and the engine is disabled. Once upon a time MB supplied low clearance hand crank jacks for that reason. Do not use bottle jacks. They will puncture right through the plastic MB jack points.
The jack points are not large enough for the floor jack and a jack stand. Meaning, jack the car up from the jack point, add the jack stand, and then remove the floor jack.
Am I overthinking this? Just want to make sure the car is secure since it will sit for a few days without a rear wheel.
I have briefly lifted one side in back by putting the jack with a wooden block under the outer end of the lower control arm. That compressed the plastic cover against the arm but did not appear to damage anything.
A dealership will not recommend a crack to be repaired because of liability and that's not their business.
I would not take repaired wheel to the track or on a 150+MPH run but neither of those is likely for a US s class.
