S-Class (W222) 2014-2020
how many you get miles on rear P Zeros?
Old Dec 30, 2022 | 01:10 PM
flohmann1's Avatar
none yet
I had my rear tires replaced in June, replacing the P Zero 275/35R20 MOE with identical new ones. Since I live in California, we haven't had any rain until recently. Now that rain has come, I suddenly notice the car losing traction in the rear, so I check the tires, and they look totally bald (see photo). Here's the thing: I've only put 3773 miles on the car since the tires were replaced. Does that seem at all plausible? I'm wondering now whether the tire guys replaced the fronts by mistake. Or if they forgot to replace the tires at all (yes, I didn't take a close look when I picked up the car, foolish me!). Am I crazy? Is this kind of wear normal? I'm not a heavy footed driver, and almost all the miles would be in around-town driving in Econ/Comf mode!
Old Dec 30, 2022 | 01:18 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Which car?
Probably not normal, I get more tire life from the similarly wear rated Michelins in the 65.
It does seem you have heavy outside wear from the picture so you do have an alignment problem.
Old Dec 30, 2022 | 03:51 PM
flohmann1's Avatar
none yet
Originally Posted by VII
Which car?
2015 S550 RWD. Looks like the date codes read 5021, so they are plausible for my June install date. I just can't quite believe that this car will eat rear tires in less than 4000 miles/6 months.
Old Dec 30, 2022 | 03:56 PM
VII's Avatar
VII
Definitely not normal, have suspension checked for play and 4 wheel alignment performed.
Old Dec 30, 2022 | 06:51 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
My Michelin Pilot AS4s are much less worn after 13k miles. Unless you are doing burnouts something is off.
Old Dec 30, 2022 | 07:54 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
a) inflation pressure ?
b.1) %-age of rapid accelerations when the light goes green ?
b.2) aggressive or casual driving style ?
c.1) %-age of time spent on interstates ?
c.2) Average speed on interstates ?
d) %-age of time Distronic is controlling speed ?
e) life of rear brake pads ?
Old Dec 30, 2022 | 09:26 PM
cfmistry's Avatar
I see where you may be going, but we are talking about a tire that is evenly worn to 2/32" at 3700miles. Even those who drive S65s/SL65s like maniacs do not wear tires quite that quickly. I still wonder if they could have missed changing these rear tires.
Old Dec 30, 2022 | 09:33 PM
vincheung's Avatar
S63, GLE580, BV250
I'm leaning towards the shop just changing your fronts or not changing any tires at all since its evenly worn down to the wear-bars in the center. If it was recent, take a look at the date codes on the sidewalls (see below link to identify it). You do need to get that alignment checked out also looking at the outer edge of the tire.
https://www.tirerack.com/tires/tiret....jsp?techid=11
Old Dec 31, 2022 | 02:37 AM
Donnymac's Avatar
63 Falcon vert
100% agree and as others have said, I don’t think new tires went on the rear. I run P zeros and I will check mileage tomorrow.
Old Dec 31, 2022 | 10:28 AM
JohnLane's Avatar
222 S-65
OP do the front tires look brand new?
I’m a savage with my S65 doing hard acceleration daily as it makes me smile and expect almost 30,000 from the pair of rear tires.
Old Dec 31, 2022 | 07:00 PM
flohmann1's Avatar
none yet
It's a real mystery. The car is gently driven (basically all Econ/Comf), I'd estimate 75% in-city miles, 25% interstates. Brakes just got done a couple months ago, so can't really tell from those.
Date codes are 5021, which seems plausible for a tire installed in June 2022. I bought the car in March 2022, which makes it hard to imagine that these could have come with the car and be so worn. The fronts show 0321 and 0521, which is about a year before I bought the car, so those don't seem new. Mystifying.
Old Jan 1, 2023 | 01:23 AM
BenzV12's Avatar
W212 FL
I was suggesting tire pressures or alignment issue as well. I have not seen a P Zero in that condition either
Old Jan 1, 2023 | 08:28 AM
cfmistry's Avatar
Good thing they have a warranty. Assuming both your rears are worn similarly, the warranty should be pro-rated and cover a majority of your expense to replace them.
Old Jan 1, 2023 | 11:38 AM
JohnLane's Avatar
222 S-65
Tires I have purchased from Discount Tire have had the mileage warranty halved due to my car being equipped with staggered tire sizes. I solved that in the 221 S-65 by fitting same size/width tires all around. This was the end of understeer. Though somehow not the end of tire wear issues. Hmmmmm....
Old Jan 2, 2023 | 06:57 PM
blackbullit's Avatar
2013 ML350, 2019 S560
Suspect tire was never replaced. Right rear always wears more on Mercedes vehicles, but not worn out in 3k miles. My P Zeros last 15k with 4MATIC.
Old Jan 3, 2023 | 03:26 PM
flohmann1's Avatar
none yet
Well, the mystery is unsolved, but the shop is submitting the tires to Pirelli to see if they will offer any credit (but they are not optimistic -- no mileage warranty on these). So that's another $1100 in tires consumed!
Old Jan 3, 2023 | 03:42 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Thats insane!
Old Jan 3, 2023 | 05:45 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
If that shop does not offer a warranty on those tires I would out them here and never buy from them again. Same with Pirelli. I have 10K miles on my Michelins with some aggressive driving on my S63 and they still look fantastic. Good for another 20K or more.
Old Jan 4, 2023 | 02:37 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
That is nuts I have the MOE Michelin's and I have put only 8k on since I bought the car but they are barely worn and yes I have a heavy right foot, something is totall wrong!!
Old Jan 4, 2023 | 06:16 PM
flohmann1's Avatar
none yet
Seems no mileage warranty on these is pretty standard? Tire Rack lists them as no warranty, as well.
Old Jan 4, 2023 | 07:57 PM
cfmistry's Avatar
Which P-Zeros do you have? It appears you are correct - the All Seasons have a treadwear warranty, but the Summer tires do not.
Old Jan 4, 2023 | 09:12 PM
2012 merc amg's Avatar
2018 S560
Ya, you should get at least 20k miles out of the rears. I generally do the rears every 20k miles and the fronts every 40K miles. Something is not right here unless you are constantly driving over battery acid or something.
Old Jan 4, 2023 | 09:47 PM
flohmann1's Avatar
none yet
Yup, the summer tires, which are the OEM standards for the 20" wheels, as far as I know.
I remain mystified. I might have been running them a few pounds low on pressure (checking the tire pressure sensor readings against a reliable gauge suggests the tire pressure sensor readings are about 3 psi high). And the tread wear certainly suggests that the alignment was off. But neither of those factors should be enough to wear them out in less than 4000 miles.
Old Jan 4, 2023 | 09:50 PM
VII's Avatar
VII
Toe will eat tires that fast if it's way out of spec
Old Jan 5, 2023 | 12:10 AM
Donnymac's Avatar
63 Falcon vert
P Zero left rear at 31K+. 85/90 % hwy miles. No wear bar visible but these tires are ready to come off. No unusual wear front or rear.
I’ll try for a wear bar shot manana.
Photographer I am not.
