Burmester 3d sound help!!
to a fair bit of rap/hip hop with a lot of base etc so to not blow the speakers I don’t usually listen to it that loud, but I swear when I put my ears near the bottom door speakers on all 4 corners (the large ones) I don’t hear sound. Is there a way to test this, I did buy extended warranty that covers the speakers so if I do have a problem I don’t mind getting it checked out. My settings are 5-5-7 and it’s on the 3d mode. Any advice will be appreciated!
thanks
I have a 2019 S63 with the 3D HE system and you should definitely be able to hear mid bass out of those lower door speakers. I did a few mods to my sub in the trunk and that helped a bit. I wrapped the sub enclosure in sound deadening and upgraded the sub to a Morel unit. Improved the bass a bit.
.... What kind of setting are you all using for 3D Burmester? Surround 3D? Surround? Or Live? I found 3D Burmester to be the best but Surround was also good and am still trying to learn the best setting and not sure about Bass and other settings to get the best out of the 3D Burmester sound system..
