Help with sound!
Help with sound!
Hello everyone I’m having a difficult time identifying the is sound that has started. I’m uploading the video so you all can hear it. It just started this. Before I take it to the stealership let me know if it’s familiar to any of you! Thanks it’s a 2014 W222
Current/Last 5-years: GLS,X5,Tesla,Accord; Sold:S560;S550,2x X7; X5;BMW 530e;Lincoln Navigator;LS460
Since you have 1 or 2 posts, I think more users would be willing to help if you don’t mind to include the video as a youtube link instead of download link. Sorry no offense, just trying to help.
Received 4,446 Likes
'71 Pinto
Part # of connecting hose & VIN look on hose.
Thats loud.
noisy fuel injectors, messed up cams, a woodpecker?
whats the car doing when you drive it?
unless your a good shade tree mechanic your going to need professional help. I would look around for a good indy mechanic that works on lots of MB's, I live in Bay area and there are many of them around and their labor rate is 50% of what the stealership has. I haven't yet dipped my toe in since I have 1 month of warranty left (gulp) but someone has to pay the six figure salary to the service writer, stock the waters and coffee machines and pay for the overhead a dealership has.
It’s not doing anything out of the ordinary. It just has that sound. I hear the injectors under that second knock. Is there a way to check all the injectors to make sure they’re all good just to get that crossed off the list?
Im a VERY good mechanic. Have been turning wrenches since grade school just never wanted it professionally. But yes you are right if I can’t get somebody to give me something on it I’m definitely going to have to drop it off.
Received 2,704 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
I am jealous I am completely lame when it comes to anything mechanical........but these cars are complex, I have an old 84' 300ZX which seems like rocket science back in the day and now is the most simple engine. But diagostic tools and computers are required now.
how many miles on it? are you able to tell if its coming from front or back, left or right? does it increase frequency with RPM?
that to me sounds like timing noise, very similar to a startup rattle I had on an ecoboost F150 before I had the recall work done. Being a 14 my money is on timing system.
[QUOTE=jcat;8749307]how many miles on it? are you able to tell if its coming from front or back, left or right? does it increase frequency with RPM?
that to me sounds like timing noise, very similar to a startup rattle I had on an ecoboost F150 before I had the recall work done. Being a 14 my money is on timing system.[/QUO
120K. It acually decreases with RPM. Only this loud with idle. Just got back from the dealership they didn’t even charge me anything because they couldn’t figure it out but offered a thousand dollar engine tear down so they can do a looky loo. Safe to say I rejected and it’s back at home with no answers.
actually more of an answer than you think.
If the sound disappears with RPM, it's likely oil pressure related which points even further to the cam adjusters.
not if it's not affecting the misfire count. At idle it probably doesn't care much. Once you rev, oil pressure builds and it's able to actuate the adjuster the way it wants.
[QUOTE=jcat;8749567]not if it's not affecting the misfire count. At idle it probably doesn't care much. Once you rev, oil pressure builds and it's able to actuate the adjuster the way it wants.[/QUOT
Any suggestions on what to do to clear that possibility?
Does it go away when hot?
Does it go away with V belt removed?
S63, GLE580, Monster 1100S
Could be the injectors cycling, but personally I’m leaning towards possibly the lifters & tappets. It was a chronic condition in the m156 (no direct injection) motors and sounds very similar. The solution that minimized ticking was two bottles of Liqui Moly MOS2. You could give it a shot as a cheap try. I’m assuming you are topped off on oil, proper grade?
yes I topped it off and checked. I performed an oil change myself. Should I pull two quarts out and put two quarts of the moly in the oil?
