iCarsoft MB II Scanner
Hello all- anyone know if the iCarsoft MB II scans for "non-check engine light codes"- i.e. a systems scan? For example, will it list faults related to suspension/airmatic system, steering, braking, drivetrain codes etc... that would normally not trip a check engine light? When I first purchased my 2015 S550, my indy ran STAR and was able to pull down a few internally stored fault codes. I'm looking for this same ability and was wondering if this more basic scanner has this capability.
I recently came across a post that this scanner was able to identify air conditioning vent faults, so I'm assuming the answer to my question is a yes. Was just curious from some folks with hands-on experience with this scanner.
I'm not looking for programming options. Just want to be able to diagnose, read run stats (i.e. transmission temp for service etc) so was looking at a more basic scanner, albeit a scanner that is more tailored to MB.
My second question- anyone know if additional software needs to be purchased for this scanner that is vehicle specific? I'd love if it worked for both my SL500 (R230) and W222.
--Thanks--
--Thanks--
2008 GL420 CDi and 2015 S500
--Thanks--
--Thanks--
iCarsoft CR PRO + Professional Diagnostic Package - ALL System, Coding, Calibration, Programming & More at £295.00
I got this one as it does lots of different models, I have Mercedes S class, Mercedes GL, a couple of Jaguars and a Ford van. This unit will work on all of them and loads more as well.
So in answer to a unit that will cover both your Mercedes then this one will do it.
I got mine in the UK from
diagnostic-world.com
If you look at their website I think it will show all the systems the units will check on.
If I go to "scan system" it runs through about 25 pages of scanning lots of systems in the car , there are some great you tube channels reporting on the units and these will show you probably what you are looking to find as well.
Hopefully the website and you tube will give you all the answers you need. I think this unit is probably a bit more expensive than a dedicated Mercedes one but may be more value overall if you ever need to help out friends and family with their cars as well.
roviw1 (04-10-2023)
It also showed an issue with something to do with a transmission control module, again this did not materialise into anything as when the car went into the dealer for a service they checked over the car and no issues were found.
Moving on to 2 weeks ago I had a fault on the tailgate of my GL , after googling it and searching the GL forum and you tube I found it may be to do with a sensor strip , someone on the forum said by using a code reader it would confirm this and give me a particular code. Straight away I went out and plugged it in and scrolled through the long list of modules it was checking until I came to one , called rear door or something similar, and lo and behold " fault on left hand sensor strip " and the code showed the same as the other chap had mentioned .
I then sorted the issue with a bypass and fitted a resistor as a temporary fix after unplugging the sensor strip, apparently these sensor strips are difficult and expensive to get if you can find one.
So far this is my only uses and I am still looking to learn a lot more about the unit, as I mentioned you tube really shows a lot of testing and reviews of this particular model , hence me choosing it. I certainly did not have money to waste so wanted to get a sensible unit that would work with all my vehicles ( and my brothers cars ( VW's and Audi ) if he ever needed to borrow it )
The unit does allow you to scan a lot of items in the car and you can then look at any current codes / faults and any historic ones, it also allows you to delete codes. It seems to be able to do a lot of other things including resetting certain things, at the moment I do not feel I know enough to delve too deeply as I do not want to give myself any bad problems by " messing about " with not enough knowledge.
I have only used it a couple of times so far, on my 2015 XJL I read a few codes and then googled them , they mentioned a few historic codes for various minor things like electric seat issues or door locking issues and also a couple of minor things, none of which i was ever aware of and were obviously random one offs I guess.
I read a lot about them and was warned by numerous people to be aware there are fake units offered for sale online and they should be purchased from a proper licenced icarsoft seller , hence me going to the company I mentioned in the earlier link.
I am pretty sure there must be a similar seller / website in the US .
Just had a quick look and this UK seller does ship overseas at a charge of £25.
Looked online and icarsoft have agents in 120 countries
iCarsoft Technology Inc.
I suggest maybe emailing them directly, I would not suggest buying from Amazon or Ebay just incase they are clone copies.
Jay04SL (04-10-2023)
Early this year I bought the following unit
best of luck
I've been searching for the same thing via the service menu on my '15 550, but am not having any luck. Nearly every trans service I've seen, the tech uses a scanner for the temp, so that may be the only way.
