4.7 L Camshaft Adjuster Magnet Harness Extension
Don
Mercedes camshaft adjustment solenoids commonly leak oil from the sealing ring or through the harness connector. If the solenoid is leaking from the electrical connector it should always be replaced and the harnesses included in this kit should be added at the same time to prevent damage to the main engine harness. This will save you money in the long run. It is a common failure on the 4.7L engines and all 2012-2020 Mercedes engines that use these specific magnetic camshaft adjusters where oil destroys your factory engine harness after time. This results in a $10K bill from the dealer to replace your entire engine harness. You plug this plug and play wire harness pigtail extensions from the engine harness to the sensors. When they start causing problems from oil spillage you simply unplug them and throw them away and replace with new ones. No special labor require. Unplug from the sensor and plug these in place. Save yourself a lot of headache and money!
We specifically made these to address the issue on the 4.7L M278 engine vehicles, but found out there are other Mercedes engines that use the same sensor.
Fits this part number Cam magnet sensor:
·A276 156 07 90
A276 905 10 00
My car is a 2015 w 46k miles. I believe the issues may be more prevalent in the 75k + mile range. But several of my sensors were wet when I unplugged them so I changed everything out.
I too only recently learned of this issue and jumped on it. There are some great write-ups within this forum, and good vids on YouTube as well covering this issue w the M278 engine.
I actually only added the pigtails to the cam solenoids although I think they can be added to the cam sensors as well. My can sensors had more oil seepage than the solenoids.
Don
A guy on EBay was selling a kit ... https://www.ebay.com/itm/17091548172...kAAOSwyb1jWuLX
On another note.....does anyone know how the "pigtails" prevent the wicking action?? Or are they intended to stop the wicking? Let's say I install new sensors and solenoids, along with adding the "pigtails". What then........Is it a situation where you should replace sensors/solenoids and pigtails if you ever see oil in the connector again?
Thanks again,
Don
Thanks again,
Don
Don
They were first issued for this common problem with the M271 (4 cyl) engine, also used for the rare case on the M272/M273 ones. Unfortunately, the problem has become a common ocurrence with the M276/M278/M157 as well. Is it a permanent fix? I see it as a time delay if the sensor or solenoids start to leak.
I have read similar issue with other brands
I appreciate your thoughts.
Don
So if you were on the fence.....its going to happen at some point...address it now. Or its happening and hopefully you catch it before it gets to the computer or ruins your whole harness.
Don
https://mbworld.org/forums/mercedes-...ml#post8718216
cheers
Don
·A276 156 07 90
A276 905 10 00
I would recommend installing these harnesses, as it takes 2min and will save you from an expensive repair bill in the future.
Hope this helps!
