S-Class (W222) 2014-2020
279 water pump failure
Old Jun 11, 2023 | 02:29 AM
JohnLane's Avatar
222 S-65
It happened. Bearing failure. Somehow it isn’t peeing coolant all over the place. Gave no warning. Drove home from work... no noises. Started it up four hours later to all those lovely sounds of a dead bearing. $250.00 for all needed parts. Doesn’t look bad to do.
Water pump is out. Same procedure as for 221 S65. Couple of bolts hide behind the crank pulley.
Worst part of it is removing the radiator fan. Parts are ordered.
Old Apr 18, 2026 | 08:17 PM
latintxn1954's Avatar
2010 Mercedes S550
W222 S550 4-Matic Remove Coolant Fan
Hi there. I too have a W222 S550 4-Matic that needs the Oil Cooler, Oil Filter Housing replaced. They're leaking oil pretty bad. Also, I'm replacing the 4 Upper Timing Chain Cap Actuators, 4 Cam Sensor. BUT first things first. I need to remove the radiator fan.
My question, did you have to drain the coolant OR did you have to do anything special to pull the fan up & out? I noticed 2 water hoses connected to both ends of the upper radiator and I'm thinking I can work the fan out if I disconnect the 2 Radiator hoses.
I've attempted to purchase & download an MB S550 Service Manual but these sites are the worst for customer service.
Any reply would be greatly appreciated.
Old Apr 18, 2026 | 08:34 PM
red996's Avatar
2013 W221 S550 2016 C217 S550
Drain the coolant from the bottom drivers side on the radiator. Remove the coolant hose on the drivers side that goes into the the thermostat.Remove the fan. Your going down a rabbit hole here. The thermostat will be broken inside. You need to remove the thermostat to remove the oil filter housing. There are turbo coolant lines in the way of some bolts for the oil filter housing. They will break if you even look at them wrong. I suggest you spice those.....
Old Apr 18, 2026 | 09:19 PM
2010 Mercedes S550
Thanks so much for the quick reply. To R\R the Oil Filter Housing, I'm aware I first need to remove the Water Thermostat Housing. I wasn't intending to replace this component but if, as you say, the thermostat breaks when removing the connecting water hose, then perhaps I should go ahead and purchase the Water Thermostat Housing as well.
Old Apr 19, 2026 | 12:16 AM
BenzV12's Avatar
W212 FL
I had to replace those offended parts in my car and coolant was all over the place after a warning . I was luckily a few minutes away from home .
Good to hear , you found the before it got worse
Best of Luck and Happy Driving
Old Apr 19, 2026 | 03:30 AM
red996's Avatar
Yea, see what happens when you remove the thermostat....I went with an aftermarket metal one. Works great!
Old May 5, 2026 | 06:00 PM
2010 Mercedes S550
Hello red996!
Just completed the job:
R/R Oil cooler & gasket. Torqued to specs.
R/R Water Thermostat Housing & gasket. Torqued to specs.
R/R Upper Cam Covers resealed & new bolts
R/R New Actuators & Seals
R/R New Cam Sensors
R/R New Serpentine Belt
Installed Pigtails to Sensors & Actuators
R/R New Turbo Cooling Lines (driver side). Purchased 2 aftermarket Lines, cut away the plastic connector ends, used new rubber tubing to rebuild.
What a job!! Not for the faint of heart. Every bolt put back & tightened to specs.
Turned the key - Waalaa.
Thanks for your tips & insight on getting the job done!
Old May 5, 2026 | 08:23 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Hello red996!
R/R New Cam Sensors
Congratulations!! I know the feeling of the first time you have to spend hours under the hood, then you crank the engine and it purrrs like a kitten. Very few things match that feeling!!
Old May 6, 2026 | 04:31 AM
red996's Avatar
Hello red996!
Kool. Having an m278 that doesn't leak oil or coolant is just, very rare. Well done.How's the front differential looking? 4 matic?
Old May 6, 2026 | 04:45 AM
Kent agent's Avatar
S600 w222
Hellohave a similar engine to yours but s600 Mine has only done 8000 miles! when did the water pump failure happen on your cars?Just changed my coolant with the vacuum method at Mercedes smells a bit burnt after the change but maybe they spilled some coolant
Old May 6, 2026 | 08:59 PM
JohnLane's Avatar
222 S-65
Your 222 S-600 will have a 279 V-12 that is very similar to mine. I got to do it at about 120,000 miles/ eight years of age. Bearing failed in my water pump. Is yours leaking coolant? Good time to give it a fresh serpentine belt, belt tensioner and idler bearings/pullies. Cooling system easy to bleed. Charge coolant doesn't get touched as separate from engine coolant.
Old May 6, 2026 | 11:56 PM
Kent agent's Avatar
S600 w222
No, it has no losses of coolant when it was tested before
Old May 7, 2026 | 08:03 AM
JohnLane's Avatar
222 S-65
If no leakage or noisy bearing your water pump should have a long life yet.
Do change coolant every four years.
Transmission oil every four years or 30,000 miles.
Brake fluid every other year.
Differential oil every five years.
ABC/MBC oil + filter every four years.
She is a wonderful car. Use her more!
Old May 7, 2026 | 08:35 AM
Kent agent's Avatar
S600 w222
I have done everything except change the MBC suspension hydraulic oil have bought the oil 12 liters and the filter but will order the AGA tool for the change 🤗
Old May 7, 2026 | 09:57 AM
JohnLane's Avatar
222 S-65
A small electric pump will remove fluid from the reservoir. 222 cars don't have bleeders at each corner so changing fluid is suck out old fluid from reservoir.... Add fluid.... Rodeo... Repeat.
Easy work.
