S-Class (W222) 2014-2020
Tire Pressure Guidance
Old Aug 25, 2024 | 10:49 PM
Donnymac's Avatar
63 Falcon vert
Originally Posted by SW20S
Alignment was totally within spec
Bald at the tread center - over inflation.
Bald at the outer edges and not center - under inflated.
Alignment by dealer or qualified Indy?
Old Aug 27, 2024 | 01:48 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Originally Posted by Mitch Alsup
What are your corner weights ??
No clue. All green on the alignment printout.
Old Aug 27, 2024 | 01:50 PM
SW20S's Avatar
2024 S580
Only bald on the outside edges, not both edges and the entire tire surface was also well worn. The car just went through front tires faster than rear tires. Alignment by both, dealer and quality independent
Old Aug 28, 2024 | 11:38 PM
Donnymac's Avatar
63 Falcon vert
The tire wear equation has a few variables in the mix.
If your suspension is stock all around, tires at a reasonable psi but not knowing your driving style or conditions, the front wear pattern indicates to much toe-in or positive camber. If your live in the city, I would bet toe issue. Or do you hit the corners a little heavy?
My 2017 just came from a fresh alignment. It lives on open hwys and it’s alignment history is camber/toe of the rears. Fronts not an issue. Trunk carries minimal weight. Car is almost never loaded and is my DD. My previous 2012 had the same issue exact issue.
Good luck.
Old Aug 29, 2024 | 05:41 PM
SW20S's Avatar
2024 S580
I don't drive super aggressively, but not gently either
Old Aug 29, 2024 | 09:26 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
I've followed this thread for quite some time. I have my 18 S63 at 49psi all around when cold. Pressure goes up to 51 most of the time, and occasionally 52psi when driving for a long time on hot days. 9 month old Michelin PS4 AS tires. Car is super quiet and glass smooth at all times, and doesn't seem to make the ride feel more harsh than when I ran my S550 at 42psi.
Old Aug 30, 2024 | 08:01 AM
  #32
ygmn's Avatar
2015 E400 Sedan
49PSI?
What is tire MAX on sidewall? those tires would be super hard and harsh in my experience.
you want soft and cushy lower the pressure - Them german engineers are quite finicky about tire pressures and do not want them blowing up on AUtobahn.
Old Aug 30, 2024 | 10:24 AM
  #33
SW20S's Avatar
2024 S580
49 PSI is way, way too high lol. The ride must be awful...42 PSI is also way too high.
Old Aug 30, 2024 | 08:22 PM
  #34
Top Answer: 1
Door jamb says 49/51 F/R for psi. Max tire pressure says 50psi on front and rear tires. Tire pressures were set by tire shop when I bought the tires. I thought they were super high too, but they felt good so I rolled with them. I bought my S550 with run-flats and thought the ride was good, but not exceptional. When I changed to some fairly reasonably priced Pirelli's, Pirelli P-Zero All season suggested by @vinflouen , the ride got much nicer and quieter. This car is actually smoother and quieter than my S550 with the Pirelli's.
Old Aug 31, 2024 | 02:42 AM
  #35
JohnLane's Avatar
222 S-65
49/51 says no pinched sidewalls or bent wheels. I happily deal with a firmer ride for that bit of cheap insurance.
Old Aug 31, 2024 | 07:10 AM
  #36
ygmn's Avatar
2015 E400 Sedan
but what does tire sidewall say for MAX PRESSURE = ???
Old Aug 31, 2024 | 01:48 PM
  #37
Top Answer: 1
Mine says 50psi on front and rear tires, but that number is the cold air fill PSI. Pressure is always going to increase when driving.
Old Aug 31, 2024 | 03:44 PM
  #38
SW20S's Avatar
2024 S580
You're looking at the wrong sticker. Its confusing but those are max pressures, you should look on your fuel door. It will be much lower, mine is 35. Tire shops over inflate tires all the time. Reduce the tire pressure to the reccomended pressure and you will be astonished by the ride and performance difference.
Old Aug 31, 2024 | 05:51 PM
  #39
Top Answer: 1
I'll give it a try; the sticker on the fuel door shows 35psi for up to 135mph and 49 for up to 186mph.
My rationale is the absolute best performance possible. I'm totally willing to sacrifice ride comfort for performance. Not so I can ever go to the track, just in case I need to make an emergency manuever, or passing on the highway safely. I want max stability, aceleration and stopping power. What's the best tire pressure for that??
Old Aug 31, 2024 | 06:51 PM
  #40
SW20S's Avatar
2024 S580
Thats just it, you aren't getting the best performance possible. Trust Mercedes, the best performance comes at the tire pressure they tell you to use.
Old Sep 1, 2024 | 04:19 AM
  #41
ygmn's Avatar
2015 E400 Sedan
lower pressure allows for more contact patch area - hence more grip.
Check F1 they only run mid 20PSI (cars are lighter for sure) but about getting more rubber to touch tarmac...Pirelli does imply a minimum pressure so the tires will cope with the high speed.
This is why MB says to raise pressure for super high-speed driving - to reduce chances of tire from over-heating and hence blow outs.
Old Sep 1, 2024 | 09:42 PM
  #42
epnfrn's Avatar
W223 S580e, Lexus LC500 Bespoke, Rivian R1S, Honda Odyssey!
agree with above - as another example, Porsche recommends over 40psi, for my 911, but anyone who ever has been on track with one airs them down to ~30 to get significantly better grip and lap times.
Old Sep 1, 2024 | 09:46 PM
  #43
blackbullit's Avatar
2013 ML350, 2019 S560
For best performance, I find that using the pressures on the driver’s door jam sticker are the ones to follow. Steering response and cornering stability are significantly better in corners. My Indy loves these pressures and says they are the best to use. The fuel filler pressures are way lower and better for ride, however sidewalls seem to be too soft and collapse when cornering hard.
Old Sep 2, 2024 | 11:31 AM
  #44
SW20S's Avatar
2024 S580
Personally, I trust MB more than I trust your Indy
Old Sep 2, 2024 | 06:18 PM
  #45
Just to be clear, MB provided those pressures, not my mechanic. They attached them to the car when they built it.
Some like ride over performance. Nothing wrong with that.
Old Sep 2, 2024 | 06:27 PM
  #46
Donnymac's Avatar
63 Falcon vert
An aggressive driver on street tires will visit the tire shop more often than other drivers. In an elevated stressed load, street tires like a higher psi, generating firmer driver feel and lower temps all contributing to tire life of a civilian street tire. Competition tires are a completely different equation built for short life, traction, stress, heat, load and are a disaster off the track.
Think about it…how many pit stops for tires in a F1 or 500 mile race? Good tire articles on www for Indy, NASCAR and F1. Very informative.
Street tire recommendations on fuel filler door are generally fine for normal driving civilian environments. Street tire door jamb data eases into MAX limit arena.
To all the above, Porsche is a great solution and a preferred recommendation!
Old Sep 2, 2024 | 06:34 PM
  #47
Top Answer: 1
For some reason this makes more sense to me than going with lower tire pressures. I think lower presures are for tires designed to go with lower pressures. Someone mentioned an F1 car running at 20psi. Ok, F1 cars weigh less than half what my car weighs, and my car has to absorb pot holes, unlike anything on a racetrack. Dragsters run even lower horsepower, but a tire for very different use. For those reasons, I'm not going to consider track usage as a guideline for street tires. My car will never see a track, but it will see several potholes everyday, along with an occasioonal high speed sweeping curve on a freeway onramp. That's an extremely high dynamic load for one tire, or 2, to endure.
Old Sep 3, 2024 | 11:47 AM
  #48
SW20S's Avatar
2024 S580
Guys, we don't have to guess...Mercedes tells us. They put the max pressures on the door, and the pressures they recommend on the fuel door. You should be using the pressures on the fuel door as per the vehicle manufacturer.
Old Sep 3, 2024 | 08:32 PM
  #49
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
I second this. There is no way on earth I will even dare to claim, or believe, that 50 PSI is even a thing for a car like this! I would never even try it. It’s wrong, surely not comfortable, and not as stable no matter whatever kind of illusion one would feel. I surely would rather trust Mercedes engineers than what I read online. Not only that, but being just 1 PSI away from the tire max pressure rating even the cold one is nothing but asking for trouble and risking other’s people life around as well. Am actually shocked that u all were even still debating this. Reading through the various posts sounds like anyway it all started by misreading or misunderstanding where the location of the actual recommended pressure is. Mercedes would gladly recommend 50 PSI if it was safe and best for the car so they can claim higher MPG, but they know it’s not the right number for the car. I mean, seriously, even their recommended tire pressure is exaggerated but at least within the reasonable range.
Old Sep 3, 2024 | 08:44 PM
  #50
Mitch Alsup's Avatar
Top Answer: 1
S600
Too little camber. Add 0.25 to 0.5 degrees of camber.
