2nd set of Brake pads and rotors after 16,000 miles
I replaced first set of brakes and rotors at 29,000 miles. quite pricey
now my brake pad light is on with just 46,000 miles. dealer said inside pad with sensor may be lower than the recently inspected wear from inspection of 7mm and 8mm.
dealer said brakes wear fast on this car from weight. I am not a heavy brake user or drive too fast.
I have never replaced rotors twice on a car especially with under 50,000 miles.
I have owned many Mercedes and always saw them as reliable and quality built. not needing brakes and rotors so frequently.
The car is great otherwise.
What is wrong?
Does the Distronic driving feature cause excessive brake wear? I do use that feature frequently
I am considering going to a small shop and just replacing pads to save cost.
Thank you.
What is wrong?
Thank you.
MB brakes wear fast. Soft (fast wearing) compound is generally quiet and smooth. And check the contact area of the rear pads - pretty paltry, it means not much pad material volume in ccs is there to begin with. Fast wearing compound + not much pad volume = frequent replacement.
Porsche on the other hand are known for brakes that squeal and groan but they stop sports cars from “elevated” speeds repeatedly. So it’s a tradeoff.
And MB assist systems such as all variants of cruise control and lane keep systems consume brakes.
Fast inner rear pad wearout is common on late model MBs.
If you use lane keeping feature, there are adjustments it uses that use the outside brakes.
Myself, I quit using distronic and lane keeping for these and other reasons. I am at 40K miles and less then ½ way through the pads.
I got 90K miles on my 2005 4Runner brake pads--something that most people only get 30K-35K.
It is how you drive it (and how you allow itself to drive).
But as the car braked itself and slowed, I would push the accelerator to speed up. Essentially driving with brakes on.
I never really thought of it that way. or realized how quickly you can wear pads down.
Do you think it's safe to just replace the pads and not the rotors? just seems like such a waste of material and money.
does the dealer add anything to the repair equation or do you think a competent small shop would be be ok?
Last edited by carlosinseattle; Aug 1, 2023 at 07:22 PM. Reason: spelling without my keyboard
so you keep the feature
One thing I have noticed is that the S560 uses up brakes and tires more than any vehicle I have ever owned. It's not a gas hog as much as it is a maintenance item consumer.
B) rather change them because they are only on one side so cost is $10
Overall I use it a lot and enjoy it for piece of mind on long trips and when in heavy traffic. Easy to turn off and take over too. And the stock brakes do make a mess. First cross country trip and the wheels were black, easy clean up, and I like how it stops.
This video eplains LKA:
This video eplains LKA: https://www.youtube.com/watch?v=myCnCAJTRAk
There are three systems to activate, not just two, Distronic, and two buttons on the dash:
1. Distronic which is the fancy cruise control system that maintains a set distance to a car in front (which is annoyingly big enough of a gap to let everyone cut in front of you, even some 18 wheelers), plus it reads signs and other wiz-bang stuff, applies brakes, speeds up, etc.; then
2. Steering Assist which keeps you between the lines (and I use this all the time, and it’s the automatic steering I mentioned, no braking, just steering); then
3. Lane Keep Assist / steering wheel shaker (which I don’t use). Yes, it’ll apply crazy braking and flash red on the dash if it thinks you’re about to do something to win a Darwin Award. And on open or curvy roads I drive all over so the shaking steering wheel is annoying.
From reading the manual and living with it I think this is how it works.
As for LKA; the lower panel button enables the system. You can fine tune it with steering wheel buttons in the assistance section, I think there are 2 levels (adaptive & Standard) I don't use it so I don't knwo how they differ. It takes some time to learn how to use all the features, and which ones you won't want to use. There are a bunch of videos like that from MB that explain all the driver assistance systems in detail.
Unlike Standard, the “reduced” nature of Adaptive is that it will NOT intervene if:
• you accelerate hard, e.g. kickdown.
• you brake hard.
• you steer actively, e.g. swerve to avoid an obstacle or change lanes quickly.
• you cut the corner on a sharp bend.
Happy driving!!
