I've read several different places that the Burmester and Burmester High End both support DVD Audio (but not SACD). However, I purchased a Fleetwood Mac Rumors DVD-A and upon inserting it into the changer, I get "disc not readable" error and it refuses to read. Has anyone with a 2014 had success with DVD-A?
Wife's asked me ... can we play a DVD/video disc in the dash display/standard system when the car is not moving/in Park? I keep telling her we should just stick one in and see what happens, but maybe someone knows?
Yes you can - it will play DVDs. With some coding from the Benz Ninja I think you can even enable the amazing dual-view screen where the driver can see Nav info and the passenger can see the DVD playing, all on the same screen.
Actually no, the code 701 "Splitview" capability is hardware and software, it requires a different LED panel. I checked with BN and he confirmed it ...
Yes, you can if you have Benzninja reprogram the stuff for you
I've done more research on DVD-A and DVD-V standards. I found this explanation helpful. There is some backwards compatibility, but only if the disc supports DVD-V format as well as DVD-A.
With the introduction of the DVD-Audio format, some kind of backward compatibility with existing DVD-Video players was desired, although not required. To address this, most DVD-Audio discs also contain DVD-Video compatible data to play the standard DVD-Video Dolby Digital 5.1-channel audio track on the disc[7] (which can be downmixed to two channels for listeners with no surround sound setup). Many DVD-Video players also offer the option to create a Dolby MP matrix-encoded soundtrack for older surround sound systems lacking Dolby Digital or DTS decoding. Some discs also include a native Dolby Digital 2.0 stereo, and even a DTS 96/24 5.1-channel, audio track.[8]
Since the DVD-Audio format is a member of the DVD family, a single disc can have multiple layers, and even two sides that contain audio and video material. A common configuration is a single-sided DVD with content in both the DVD-Video (VIDEO_TS) and DVD-Audio (AUDIO_TS) directories. The high-resolution, Packed PCM audio encoded using MLP is only playable by DVD players containing DVD-Audio decoding capability. DVD-Video content, which can include LPCM, Dolby or DTS material, and even video, makes the disc compatible with all DVD players. Other disc configurations may consist of double layer DVDs (DVD-9) or two-sided discs (DVD-10, DVD-14 or DVD-18). Some labels have released two-sided DVD titles that contain DVD-Audio content on one side and DVD-Video content on the other, the Classic Records HDAD being one such example.
Unofficial playback of DVD-Audio on a PC is possible through freewareaudio playerfoobar2000 for Windows using an open source plug-in extension called DVDADecoder.[9]VLC media player has DVD-Audio support[10] Cyberlink's PowerDVD Version 8 provides an official method of playing DVD-Audio discs. This feature was dropped from version 9 onwards.[11] Creative also provide a dedicated DVD-Audio player with some of its Soundblaster Audigy and X-Fi cards.[12]
