S-Class (W222) 2014-2020
Suspension clunking
Old Sep 13, 2023 | 03:08 PM
stoneycreek's Avatar
2001 BMW 750il, 2018 Audi A6 SC, 2015 S550 LWB, 2007 Audi S8
Exclamation Suspension clunking
Hello friends.
I have a 2015 S550L 4matic with 66.000 miles. I have been chasing this subtle thumping or clunking noise for months now. I have been under the car many times, could not see anything out of the ordinary. I have even replaced sway bar links and that did not make a difference. It is mostly steady and consistent on uneven or bumpy road. I do not have any suspension issues, no leaks, car does not pull to the side, except for this thump sounds. When the car is parked and if I turn the wheel side to side to rock it, no noise or thumping. I have attached the video link here,THUMPING NOISE, please ignore the cabin noise and listen to the constant thump as I sway the car left and right in the parking lot. This thump is always the same and at the city speeds. I did not notice it on the highway. I will disconnect the sway bar to eliminate the sway bar assembly and see if it thumps than. What I have seen in my search trough the innerwebs, people have either replaced passenger shock absorber or sway bar link components. If it is the shocks, what's the best place to get them, meaning reliable and cost effective? Thanks and your opinions are appreciated.
Old Sep 13, 2023 | 10:24 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Usually that is control arms. Probably the lower ones.
Check the rubber bushings for wear or cracks.
Old Sep 14, 2023 | 04:35 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Sway bar links, they can go out every 50k if you're hard on the car or hit bumps at an angle quite often. The rest of the suspension is fine.
They're a spherical ball in a plastic cup, they're cheap enough and you can just use simple hand tools to install.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Sep 14, 2023 | 09:34 AM
I have removed the sway bar from the car, took the car for a spin and noise is gone. I took it to work today as well, no thump or noise. Sway bar links I have replaced 5 months ago, I don't think they are gone. I have ordered sway bar bushings. Since sway bar bushings are part of the sway bar, fused together, I had to order an aftermarket bushings from China .
Old Sep 14, 2023 | 02:05 PM
Sactownmb's Avatar
MY 18 S450V RWD Diamond White
At 66k possible engine or transmission mounts ??
Old Sep 14, 2023 | 02:16 PM
Regarding Engine mounts : Good point and I heard engine mounts are a nightmare to replace. Also when they are gone its noticeable as a constant shake when engine is running, starting and shutting off. I don't get any of that.
Old Sep 14, 2023 | 02:18 PM
Good point and I heard engine mounts are a nightmare to replace. Also when they are gone its noticeable as a constant shake when engine is running, starting or shutting off. I don't get any of that.
Old Sep 14, 2023 | 03:27 PM
waterzap99's Avatar
S550 V8, CL600 V12, SLK32 AMG
The full sway bar is only $160 OEM from Mercedes
Old Sep 14, 2023 | 03:29 PM
I have seen them on line for $360. Interesting and thank you. I am calling the dealer right now
Old Sep 14, 2023 | 03:33 PM
waterzap99's Avatar
I was looking at this one. Might be the wrong one, but cant believe it would be much more.
Stabilizer Bar - Mercedes-Benz (222-323-12-65)
  • MSRP:$218.00
  • Discount:$56.68 (26% off)
  • Sale Price:$161.32
S450. Sedan, without 4-matic. S550e. S560e. Sedan, rwd. S600. S65 amg. Cabriolet.
Old Sep 14, 2023 | 03:40 PM
  • MSRP:$218.00
Just called my dealer here and stabilizer bar or sway bar is $470 Canadian.
Where are you looking at for the above price, yes that is the correct one.
Old Sep 14, 2023 | 03:51 PM
I found it where you saw it I think, https://www.mercedespartscenter.com/
They don't ship to Canada, at least we are on to something, thank you
Old Sep 14, 2023 | 03:55 PM
waterzap99's Avatar
mboemparts
Old Sep 15, 2023 | 03:29 AM
SPONSOR
don't do that I've used those before and they're not a great fit and you get play/creaks over time
the links are probably fine.
Also mounts don't go out at 66k, they can last up to 150k
__________________
Old Sep 15, 2023 | 07:53 AM
mboemparts
not shipping to Canada
Old Sep 15, 2023 | 08:22 AM
Thumbs up
mboemparts
Found Canadian site, thank you, I have contacted them for pickup. $260 CAD, better than $460 from dealer
Old Sep 15, 2023 | 10:58 AM
W205C43PFL's Avatar
Mind sharing the site for us forum members who are also in Canada?
Old Sep 15, 2023 | 11:00 AM
Sure thing.
www.mbparts.ca
Old Sep 15, 2023 | 06:23 PM
W205C43PFL's Avatar
Sure thing.
www.mbparts.ca
Much appreciated.
Old Oct 16, 2023 | 08:32 AM
To update. Over the weekend I had a friend come over and help me diagnose the thump in the front end. Work I have done so far: Replaced stabilizer bar links and bushings. Replaced front shocks. Thump still there. Front end is rock solid, no movement anywhere. I have raised the car on the ramps so I can get under it. Had a buddy open the front door and push against the roof line to rock the car to mimic the car motion. And, the thump was there. I went under the car and was able to see and feel where the problem was. Well, brand new stabilizer bar links were *****. Felt the play and knock in both sides, which I could not reproduce with the wheels up in the air. So, burned money on the new shocks, stabilizer bar bushings and stabilizer links. Links I am going to try to warranty and new ones I have ordered from the dealer. Stay tuned for the update tomorrow.
Old Oct 17, 2023 | 05:06 PM
Update, CLUNKING SOLVED
I have replaced the sway bar links that I have replaced already in April this year. This time I bought them from dealer. Clunk is officially gone. Car drives like brand new again. Thank you all for of your comments.
Old Nov 11, 2023 | 09:35 PM
W205C43PFL's Avatar
That is good news, now enjoy your vehicle in good health : )
Old Nov 12, 2023 | 03:09 AM
BenzV12's Avatar
W212 FL
Nice to hear it was solved and I also appreciate your feedback on your issue as well
Happy Driving
Old Nov 12, 2023 | 05:58 PM
waterzap99's Avatar
Also replaced the sway bar links this weekend. There was a bit of a noise, gone now.
The passenger side bottom side was not totally tight. Not sure if not tightened in factory or just came loose over time.
It was about a three hour job.
Getting them torqued tight was the biggest problem. Have to lift up the suspension with a floor jack and then crawl down in there to tighten things. Not a lot of space.
Of course with a full lift it will be much easier.
