S-Class (W222) 2014-2020
Rear break light question.
Old Oct 21, 2023 | 07:13 PM
Bkbenz14's Avatar
S550
Noob questions however, my wife was driving behind me and said my two top lights where not engaging when i break.. do i have a fuse out or bulb.Also, is there thread on brakes squeaking upon backing up in reverse i couldn't find a thread to this issue i am sure there is a few i herd this maybe due to some grease points that need to be lubed up every year or so. Breaks were just check and all is good. But still get a squeaking on reverse.
Old Oct 22, 2023 | 10:24 PM
mercedesbuff's Avatar
'20 GLS450, '17 S550 Sedan
Originally Posted by Bkbenz14
my wife was driving behind me and said my two top lights were not engaging when i brake.. do i have a fuse out or bulb?
In my 2017 W222, the brake lamps only illuminate in two of the three tail lamp "outlines," just as your picture shows. Therefore, I believe this is operating normally, unless someone else here can show a different experience.
Hope this helps!
Old Oct 24, 2023 | 12:08 PM
NbyNW's Avatar
Veteran: Navy
Various
Do any US S-Class have the rear fog light?
Old Oct 24, 2023 | 08:43 PM
Bkbenz14's Avatar
S550
Thanks, that all i needed to know being a new S class owner.
Old Oct 25, 2023 | 06:30 PM
No Rear Fog Lamp in U.S. (W222)
I do not have a rear fog lamp button in my 2017 W222.
Old Oct 25, 2023 | 08:56 PM
NbyNW's Avatar
Veteran: Navy
Various
Same here, no light. The owners manuel shows it as you noted. Wondered if certain cars had it.
Old Oct 26, 2023 | 01:47 AM
95Sinned420's Avatar
2016 S550
My older benzes all had rear fog lights. I've also used it when needed..but admittedly, 99% of the road users would just think something is wrong with my taillights. Pretty sure thats why they got rid if it for the US spec cars?
Old Oct 26, 2023 | 07:09 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
On BMW's, the wiring and bulbs are there for rear fog lights, and to enable them it's only required to obtain the required Euro-switch and connect it.
Does anyone know if this is the same for the W222?
Old Oct 26, 2023 | 02:35 PM
W222 Rear Fog Lamp (NON U.S.)
Same here, no light. The owners manual shows it as you noted. Wondered if certain cars had it.
I believe the W222 rear fog lamp used entirely separate hardware in other parts of the world, rather than working via the existing tail lamp housing. The photo below shows what I think the European fog lamp (center of rear bumper) looks like. I could be wrong...
