Best Tires for S560 4Matic
When you came to curved overpasses on the interstate, you had to line up the car towards one edge of the pavement, aim at the other side at the middle of the overpass, and hope to get traction before running off the road at the other side.
I was using "rain tires" because you bought them in the fall before the rains started and later snow, and the tread would last until about summer whence they became slicks with more traction during the dry season. {{This was 1976 way before the R-compound revolution}}
I have P-Zero Nero run flat now on my S560. They are OK. I honestly can't say there is much difference. My car is low mileage. When it's time to change I may go back to Continental.
Will see, I have barely driven them. I'll report back at the end of the season. Btw what size are you running? I'm on 245 45 R19/275 40 R19.
I can tell you without hesitation, that these products are sometimes produced with flaws. Why not - it's a human-designed, human-made product with humans involved in the manufacturing process. It just happens, regardless of how many times a mold is used in production. Catching bad v-belts in our warehouse when completing an order for vibration-checked belts, most FHP belts going on heating or A/C units, and matching a group of belts to produce a matched set for an industriasl application was where we would find the bad items. The problems were not visible or could not be ascertained or discovered just in handling the belt.
