Looking to prepare for a new car in the future
https://mbworld.org/forums/s-class-w...sket-leak.html
Note this is not a common failure on this engine, the M177 and M178 are more common but this is the first one in an M176 the dealer has ever seen.
If you only use 50 HP of a 500 HP engine, you are putting so little stress on the engine that it having 500 HP is irrelevant.
Stress is quadratic WRT RPM and linear WRT cylinder pressure,
Full throttle at ½ redline is ¼ the stress of full throttle at redline.
Redline at ½ throttle is ½ the stress of full throttle at redline.
There are other parameters, too::
Redline when the oil is at 220ºF is a lot less stress than redline when the oil is at 270ºF.
water temps
transmission temps
differential temps
Stress is based on how YOU drive the car.
Keep those extended warranties flowing!
If I could sum it up one way I'd say these cars are miraculous at delivering what they deliver. In order to accomplish that, they're are operating at a much higher level than in the past That applies, to engineering, materials, assembly, components, operating envelopes, etc. Maybe I'm jsut different, but I believe these cars are awesome, I don't expect to get the best for nothing. It's a disservice for me to tell somebody they should expect Camry level operational cost with an S-Class. Funny thing is we all this applies to petty much everything else in life, why should cars be any different?
They had the car for 8 days, the book time is 24 hours so regardless of how many hours it takes thats what they are going to bill. The parts come in a kit from MB apparently.
If you want DIY, this is a DIYable job if you know what you're doing its just a big job.
The engine in question is 1990 Jaguar XJR-12. They used 7,300 RL for sprint races, and 7,000 RL for endurance races.
This is entirely in line with my quadratic statement above (which I got from a book about building race engines; and one you disagreed with.)
The point is::
a) if you are always banging the engine off the redline, engine life is reduced.
b) if all you do is cruise down the interstate at 2.500 RPMs the life of the engine is essentially infinite with good maintenance.
c) the drive chooses how long the engine lives
d) so does maintenance.
Their problems and heavy maintenance makes me question the whole architecture.
I certainly would not want one. Heck, I did not even "want" the turbos in my S-600.
Having become used to turbo power I don’t want to go back to N.A. power.
https://www.bing.com/videos/rivervie...4D1D&FORM=VIRE
BMW N63 Engine Problems - Causes and Solutions (bmwtuning.co)
In your own words, what is the 25-words-or-less summary of the N63 heavy maintenance?
