“Can’t recognize key fob”
I’m sorry but I can’t make heads or tails where the key goes to manually start the car. I found the key symbol where the cupholder is but I don’t know how that is supposed to work - isn’t there some spot to insert the metal key?
Somehow the car started but the warning was still on the dash and as I drove back home to get the other key the car loudly beeped constantly all the way.
I replaced the fob battery, the old one was really corroded. The car started and I drove about 2 hrs. The car was parked for 4 hrs and when we had to leave it wouldn’t start. Apparently unknown to me my son removed the battery to see if it could be any water inside the fob. i discovered He installed the battery upside down. The key fob is still not right and even if it starts it’s completely unreliable. To top it off my other key is missing now. To day is devoted to tearing the house apart looking for that missing key.
I must have some bad karma somehow.
Rich
Rich
That said, washing the fob (or moisture getting in basically) may had impaired this function. The metal key is only used for locking the glovebox and open the door from the driver side handle when the fob is out of battery. There is a hole at the bottom of the handle to push the plastic cover off the handle to insert the metal key.
So despite what I’ve read - there is NO WAY to start this car unless you have a working fob. It might be a good bet this was the first fob battery installed when the car was assembled in July 2017 so it didn’t take much to kill it.
I just have to be better prepared should a key fob fail for other than washing mishaps down the road
1. Remove keyhole cover on drivers door handle corner, remove key from fob and unlock door. Alarm will sound when door is opened.
2. Hold fob at the key icon in center console, brake and press start. Vehicle will start, alarm will stop.
The fob needs to be in working condition as it is not magical, wireless power and data will be transmitted between vehicle and key.
Mercedes keys have some water resistance but not really enough for a clothes washer.
Well, again to the op's relief : Mercedes-Benz keyfobs are solid not fragile .
