Front Brakes pulling
There are so many factors which could influence this behavior, and the brakes are only one….
did you check caliper slides?
Pad slides?
how do you know calipers are not stuck? did you jack up and remove tires and do what?
were pads tight and would not move or a little bit of clearance?
after you drive, and hard braking is one side hotter then the other?
Pad slides?
I have 12 days left on the warranty so I need any defects now. I just don’t want the dealer to come back saying the problem stems from a maintenance category and I have to foot the diagnostic fee of $212. It’s still wet out so I can’t test yet - dealer appointment is on this Thursday morning.
did you check caliper slides? “See above response”
Pad slides? “See below”
how do you know calipers are not stuck? did you jack up and remove tires and do what? “I have a 2 post Mohawk 10,000lb lift, removed wheels, lowered car with help applied brakes after I removed calipers compressed pistons checked sliding. Without any pedal pressure rotors can turn - with pressure cannot turn. Pads are tight in calipers - rotors are smooth, no glazing, no hot spots.”
after you drive, and hard braking is one side hotter then the other? “I shot several spots (with temperature gun) around the brakes/calipers and rotors immediately after an 8 mile run. Temp difference is less than 10% left to right.”
The nose dive is a little more concerning t9o me than the side to side veering. That could be caused bay a bad proportioning valve. But it can be reset/balanced fairly easily. If it doesn't balance then you know you have a problem.
