S-Class (W222) 2014-2020
Radiator flush
Old Jan 13, 2025 | 11:15 AM
bdunn's Avatar
2018 S450 4Matic, 2021 Toyota Tundra, 2010 GL350 (sold)
Radiator flush
So when I bought the S450, I don’t know for sure who put oil or anything else in it last, so I’m replacing the easier fluids.
Question: Anyone know of a reason I can’t use my new Mityvac to pump out the coolant instead of draining it?
Old Jan 13, 2025 | 12:34 PM
DaveW68's Avatar
Veteran: Army
2015 S550
You won't be able to extract the coolant. Draining it is the only way to clear the system. And I believe it has to be done by removing the lower radiator hose.
Old Jan 13, 2025 | 03:06 PM
bdunn's Avatar
Oh man… that sucks. Speaking of sucking we did the oil change using Mityvac - SUPER EASY.
Old Jan 15, 2025 | 12:21 AM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
On the driver side there should be a little valve at the bottom of the radiator, you can open this valve to drain....nice and neat...
Old Jan 15, 2025 | 12:34 AM
bdunn's Avatar
Okay thank you! I will look for that. That’s a petcock valve?
Here’s where I am puzzled. I only have access to what I would call the overflow container, not the radiator. How do I fill the entire system up and make sure there are no bubbles somewhere there shouldn’t be? I know some systems bleed automatically.
Old Jan 15, 2025 | 06:57 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
You fill it....and get your buddy with Xentry to run the coolant program on it. It rev's the engine, turns the heat/defroster on and off and cycles through systems for a bit.
Old Jan 15, 2025 | 02:27 PM
bdunn's Avatar
I have Xentry. Is that pretty simple to do or should I get @BenzNinja involved I this?
Old Jan 15, 2025 | 02:45 PM
If you have xentry you need nothing more.
Old Jan 15, 2025 | 03:39 PM
bdunn's Avatar
Does anyone know the steps once in Xentry? All I’ve done to date is set that up for BenzNinja to connect. I would image this is an easy process but I haven’t the first clue. I can get to the diagnostic screen and look at any issues.
Old Jan 23, 2025 | 04:43 PM
waterzap99's Avatar
S550 V8, CL600 V12, SLK32 AMG
How I do it, and not saying anyone should follow
- Drive up on ramps
- Take off the middle cover under the car - 8mm bolts
- Take off the front cover - 8mm bolts
- Get a big flat sterilite type plastic container from Walmart
- Loosen the drain in the radiator. Also the cap from the overflow container
- Go get a beer. Come back in 30 min.
- Close the drain
- Get a bucket with 50/50 coolant and something like this
M31 Vacuum Type Cooling System Filler Tool Set - just search on Amazon - $50
There are thousands of them on Amazon. I found that the cone shaped adapter seals best.
- Use compressor and the tool, pull slight vacuum and put coolant back into system.
- Put everything back, start the car, make sure the level is still good.
- Maybe just drive around the block, check level.
- Verify level for about a week. If any air works itself out.
Thats it.
As you drive the car around, put it on heat, so the new coolant works itself in everywhere.
Of course I am not getting every drop of old coolant out, but I do this every year or two so that I don't care.
Old Jan 23, 2025 | 05:06 PM
waterzap99's Avatar
And before anyone says I change my coolant too often.
Neighbor had a Jeep Grand Cherokee, bought new ( I know..Jeep..still). Still had less than 60k on it, only few years old
He had to replace the waterpump. Anyway, when he took it off, that engine had so much pitting on the block, there was no way that was going to seal.
However expensive coolant is, a new engine is way more
Asked him when last he replaced his coolant, he said, never, its not needed.
Ok.....
Old Jan 23, 2025 | 05:17 PM
bdunn's Avatar
- Drive up on ramps
- Close the drain
Thats it.
This is awesome! I need it spelled out to me sometimes and I had no idea a vacuum for the cooling system could be only $50. Thanks so much!
Old Jan 23, 2025 | 05:18 PM
bdunn's Avatar
Ok.....
Man that’s sad. It’s not the mechanical engineers saying 10k oil changes and forever fluids. That’s SALES. People just don’t realize.
