S-Class (W222) 2014-2020
my W222 cabin smells like feet - help!
Old Apr 16, 2025 | 11:13 AM
ashorthaul's Avatar
W222
Hi
I have a pre-facelift S350.
For three years now when I do a hard turn, or any aggressive movement with the car, I get a sudden musty smell in the cabin - it smells like feet/old socks! The smell is gone quickly but it is very annoying.
I did spill some powder in the boot (building materials) about three years ago, and suspected that this powder had gotten into the cabin/vents somehow - however is this even possible if the boot has no vents or air connectivity to the cabin?
I noticed recently when I hoovered the boot again aggressively and had the auxiliary battery in there replaced, the smell became a bit worse in the cabin.
I did get a third party to use one of those air con cleaners and change the cabin filter about a year ago - but this didn't make any difference.
Any ideas?
Thanks!
Old Apr 16, 2025 | 12:12 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
I had an W220 S600 years ago that smelled horrible. It took me a couple years to realize it was clogged suroof vents. See if your suroof drain tubes are clear or not. The easiest way is to find the outlet under the car and blow compressed air up. Also, clean air comes through the cowling under the hood and through the firewall to the cabin. Sometimes water can get trapped and form a murky pool of dirty water. Not sure of the terminology in your country, but it's the cowling in the US. The cabin filter would have been another guess, but you took care of that already.
Old Apr 16, 2025 | 01:18 PM
chassis's Avatar
2017 GLE350 4MATIC
Mercedes dirty sock HVAC smell. It comes from the factory, no extra charge. MB doesn’t know what they are doing.
Read this site for more.
Old Apr 16, 2025 | 02:54 PM
W205C43PFL's Avatar
It is either the clogged drains or the HVAC mentioned, there was a lawsuit for a moldy smell: https://www.lieffcabraser.com/defect...-benz-ac-mold/
Old Apr 18, 2025 | 06:02 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
While not a common problem with modern MBs (they have an evap dry routine), have the evaporator drains cleaned and the the evap filled with neutralizing foam, change filter and odor should be resolved.
Old Apr 19, 2025 | 02:30 AM
vincheung's Avatar
S63, GLE580, BV250
Blast the heat at its highest temp, highest velocity, windows down for a good 15min to get as much of the mildew out of the hoses as possible.
When running air-con, try to make it a habit to turn off the AC function 5-10 min before arriving and shutting the car off. This will bring the hoses up to ambient temp and reduce moisture buildup inside.
Old Apr 25, 2025 | 01:15 PM
MB221's Avatar
W222 400D 4-matic
Same problem here. Cleaned the evaporator in compliance with MB rules and regulations twice now and..still that smell. Checked all drains miticiously and there's no intrusion or standing water. Might it be just plain mould in the airtubes?
Would a Ozon-cleaner-device doing its thing a whole weekend help?
Old Apr 25, 2025 | 01:19 PM
VII's Avatar
VII
Ozone would help (but do note that it's destructive like UV).
What sort of climate are you in?
Old Apr 25, 2025 | 02:01 PM
MB221's Avatar
W222 400D 4-matic
Its streetparked in The Netherlands, not in a parked garage. Changed the filters, did the charge yearly, all maintenance as MB required (and more) checked and confirmed that the panoramaroof 2 frontdrains work and idem the 2 wiperdrains. No wet carpets. No smell when opening a door. But like OP states, when cornering especially in city-driving i can defenately smell that odor. When on the highway there's hardly a problem.
Old Apr 27, 2025 | 01:14 AM
Top Answer: 1
You're parking your car outside in the elements. I'm sure your sunroof drains are clogged. What happens when you pour water in the suroof rails? Do you actually see the water dripping from the bottom of the car? Try it on both the front and back and on both sides.
Old May 5, 2025 | 04:06 PM
MB221's Avatar
W222 400D 4-matic
I took her to my mechanik and explained him the issue. Keep you updated.
Old May 5, 2025 | 04:23 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
This is a common complaint for many, many cars. I would run some A/C duct cleaner through the system and see if that helps
