S-Class (W222) 2014-2020
2018 S560 gas leak from tank?
Old Jun 4, 2025 | 01:53 PM
Robb92914's Avatar
S560, GLS63
Getting a strong gas smell every morning when I start it for about 2 months (persistently got worse). The other day I went to fill it up and gas started leaking out from under the car.
Took it to the dealer (Mercedes of Clearwater) and as always, they cant find anything. They did the fuel line campaign a couple years ago and said it cant be that. They said they do not see a leak and I assured them I watched it leaking.
Has this happened to anyone? Thanks in advance!
Old Jun 4, 2025 | 03:18 PM
waterzap99's Avatar
S550 V8, CL600 V12, SLK32 AMG
Bad gas cap?
Gas cap has an overflow. Not likely leaking, but easy to check at least.
Something else that is back there probably the evap canister. Usually fuel doesn't go in there though.
Best might just be get some ramps and reverse up. Or maybe an inspection camera and peak under the car.
Lots of hoses running back there, but then the dealer said they couldn't find it.
Thats a big leak.
Old Jun 4, 2025 | 04:33 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Does it smell every morning before doing anything, or only after you activate ignition?
Old Jun 4, 2025 | 05:44 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Can someone remind me what the "fuel line campaign" was about ... was it something about a leaking fuel line under the rear seat (smell inside the car) or something different?
it sounds familiar but now that I have an S560 would like to refresh my memory ...
Old Jun 4, 2025 | 06:46 PM
VII's Avatar
VII
The one that comes to mind is fuel leaking in the valley of the engine due to heat aging of rubber hose.
Recall was revised to add silver heat shield as initial revision of material did not solve issue.
Old Jun 5, 2025 | 07:58 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
The gas leaking while filling the tank is something commonly associated with a failed seal at the fuel pump. The pump can be accessed under the rear seats. I've had this on my W221 and W212, but replaced the fuel pump on my W222 when I got the car due to mileage.
The easiest way to confirm is to remove the rear seat bench (or right side rear seat if you have reclining rear seats) and check the top of the fuel tank for leaks.
Here's a good thread on the topic.
https://mbworld.org/forums/s-class-w...rked-s560.html
Old Jun 5, 2025 | 01:37 PM
Craig Ewing's Avatar
‘11 C300 ‘11 C350
Recently had a code P0456 (EVAP small leak) on my 2011 C350, YouTubers showed leaks found at fuel filter and pump access cap on C class, E class, S class, CL class, and ML class vehicles.
My access cap was wet so replaced and topped off fuel, next morning fuel filter was now wet so replaced.
On both parts it looked like fuel had seeped through electrical pins when tank was full.
It’s been a couple months no further issues.
Old Jun 5, 2025 | 03:35 PM
xabo's Avatar
'20 S63
Here you are:
Old Jun 5, 2025 | 06:40 PM
Thanks, very interesting ... I'm guessing if that line has the insulation covering - either from this svc campaign or as built in the factory - then you're ok. What was the failure symptom for this? A smell of gas from the leakage onto the engine?
Old Jun 5, 2025 | 06:44 PM
xabo's Avatar
'20 S63
OP, may be of some interest to you.
File Type: pdf
File Type: pdf
