S-Class (W222) 2014-2020
Still hot as can be
Old Jun 25, 2025 | 03:50 PM
MrMischief's Avatar
From: Bucks County PA not far from the Delaware River North & East of Philly by an hour.
‘68 Pontiac convertible, ‘71 Corvette 4 spd, ‘20 Accord Touring, 06 Duramax crew-c
Still hot as can be
With all the insulated glass, factory tinted windows, sun roof closed (and I thought there was some sort of power vent in these cars), it’s still hot as can be in my car. I hate to vent the roof or the windows (when I plan to go out again) because a wasp or bee could fly inside. I’ve actually burned my arm on a couple surfaces inside the car it was that hot.
I really don’t like fooling around with those reflective window covers people put in against the windshield.
All that expensive glass and I don’t believe it’s any better any other car.
Rich
Old Jun 25, 2025 | 03:55 PM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
Umm...if you don't leave a window or sunroof cracked and you won't "fool around" with a sunshade - what exactly are you expecting ? Your car is a greenhouse and will become super hot without either ventilation, window shades or both.
There is no magic answer here - crack a window, use a sunshade or park under a tree.
Old Jun 25, 2025 | 10:27 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
The windows are sadly not magical.
The thermodynamics are rather simple, the car takes in radiation from the sun and looses it by convection.
The convection is fairly weak as vehicle is very well insulated.
The non magic windows reduce the speed at which the temperature rises by reflecting a portion of energy heavy IR but only have a small effect on the final terminal temperature of the vehicle.
Regardless of ambient terminal temperature the surface temperature surfaces receiving radiation is more important for human comfort.
A sunshade greatly reduces the biggest source of radiation while preventing surfaces from reaching temperatures far in excess of ambient air.
​​​​​​Also if you have a leather dashboard it will help prevent shrinkage.
Old Jun 26, 2025 | 05:34 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
Park under a roof.
Old Jun 26, 2025 | 09:44 PM
JohnLane's Avatar
222 S-65
Newsflash! The car gets hot inside when parked outside during the summer!
OP either you park it in a climate controlled garage or accept that as with every other car on the road... it will be uncomfortable after sitting in the sun during summer.
Here in the valley of the sun even with the shade across the windshield and blinds deployed.... there are surfaces in the car that will quickly make for burns.
You could move far enough North that it doesn’t get hot in the summer.
Old Jun 27, 2025 | 12:12 AM
W205C43PFL's Avatar
Is the interior dark or in light material? That plays a role as well.
Old Jun 27, 2025 | 12:33 AM
BenzV12's Avatar
W212 FL
Sunroof tint should also be able to reduce the heat but I have not tested it in any car . I also don't like reflective covers as those look funky to me lol
Old Jun 27, 2025 | 12:46 AM
W205C43PFL's Avatar
When I came to this thread, I honestly thought OP meant the car is beautiful hence "hot" so I was here for pictures...
Old Jun 27, 2025 | 01:21 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
https://www.bestproductsreviews.com/...xoCtz0QAvD_BwE
Solar powered fan, fits in window rolled down a crack, and lowers temperature in car to ambient.
Old Jun 27, 2025 | 04:09 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
In today’s day and ahe it might just be easier to not believe in the greenhouse effect. Seems to be a popular opinion for many..You must be imagining it.
jokes aside, the only way to get rid of the heat is to get rid of the sun. If this is a new concept, please remember not to leave your children or animals in a locked car in the sun with the windows up. In the current heat wave, the interior of a car can easily reach near 200°F…. because when it’s near 100° in the dark, it’s still 100°…add some sun, bam, heat…lol.
And because maybe I feel this is incoming, the water under your car is from the air conditioning and it’s called condensation. You can’t do anything about that bit of science either
in the words of Jesse Pinkman “magnets!”.
Old Jun 27, 2025 | 12:26 PM
MrMischief's Avatar
The point I intended to make - despite the marketing MB makes for the IR blocking glass on our cars that lays claim cooler interiors my car is no better heat-gain wise than any other car I’ve had. Oh, and I so enjoyed the lessons in thermal dynamics, I can’t wait to work that into my conversation at dinner tonight.
Old Jun 27, 2025 | 12:54 PM
joeshannon095's Avatar
2018 S560, 2004 SL500, 2014 S550 (SOLD), 2012 S550 x2(SOLD), 2007 CL600 (SOLD), 2007 S600(SOLD)
This is a nonsense post. Once cooled the interior will stay cooler than a car without IR glass. If you don’t want to vent the sunroof and refuse to “fool around” with a sunshade then don’t complain when a car is hot on the inside in the middle of summer…
Old Jun 27, 2025 | 03:25 PM
Top Answer: 1
S600
Given an object with ANY Albedo, sitting in a 100ºF environment without sunlight, the car will always stabilize at 100ºF
Given an object with non-zero albedo sitting in a 100ºF environment with sunlight, the car will always stabilize higher than 100º.
The black roof on an S-class absorbs a lot of infrared heat and convects significant amounts of that heat into the interior.
.....This causes the interior to become significantly hotter than the external environment.
.....Tinted windows INCREASE this heat gain.
The answer is to keep sunlight from hitting the black roof--thus keep the car in a garage or car port.
Old Jun 27, 2025 | 03:35 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
I have not found this to be true. When I get into our Pacifica which does not have IR rejecting glass there is a big difference in the heat that comes from the windows...Its very noticeable when driving in the summer with say my arm up on the top of the door panel.
Now like others have said its not magic, its similar to the heat rejection you get from good window tint. The car is still going to get hot if it sits out. Why not use the remote start from the app to start it up and let it cool down before you get into it? You also could have the windows tinted with good ceramic film and that will also improve the heat rejection even further.
Old Jun 27, 2025 | 11:53 PM
W205C43PFL's Avatar
Some makes offer to have the sunshade closed while the sunroof is open, that solves the bee and other insects from entering that OP was concerned about. Given that thought, I wonder if custom coders on the forum is able to code the car to have the sunshade closed while sunroof opened?
Another thing is residual heating (in the winter) residual cooling (in the summer) for 30 minutes.
Old Jun 28, 2025 | 12:20 AM
BenzV12's Avatar
W212 FL
That was my initial thought as well .
Well, I also think that Mercedes-Benz use thinner shade than other manufacturers , not a problem for me
Old Jun 28, 2025 | 01:04 AM
W205C43PFL's Avatar
We still need pictures : (
Old Jun 28, 2025 | 10:04 AM
gtstodd's Avatar
GL550 / AMG GTS
Hot Hot Hot
Old Jun 28, 2025 | 11:08 AM
SW20S's Avatar
2024 S580
Not on the S Class. It uses a typical thick shade. All the other models use a thin shade.
Old Jun 28, 2025 | 01:44 PM
Quietride's Avatar
This is the thing I really miss about EVs, especially having a baby. You never enter a hot car since they can remotely climatize anywhere.
Old Jun 28, 2025 | 06:07 PM
SW20S's Avatar
2024 S580
Just remote start and its a non issue
Old Jun 28, 2025 | 06:34 PM
UltraSpeed's Avatar
GLS450 S550
Right!
Old Jun 28, 2025 | 11:37 PM
W205C43PFL's Avatar
This. I must had missed it but did OP said they didn't want to do any sort of pre-climatization?
Old Jun 28, 2025 | 11:58 PM
W205C43PFL's Avatar
nope, OP did not say anything about not wanting to remote start, there you go then : )
Old Jun 30, 2025 | 01:18 PM
MrMischief's Avatar
I’m not paying MB a fee just for remote start. If the Sclass was like many other cars with remote start without a membership fee then I would certainly use it.
