S-Class (W222) 2014-2020
2018 S560 Fill Radiator fluid sensor?
Old Jul 25, 2025 | 09:49 PM
jsconiers's Avatar
Other
I have a 2018 S560 4matic. Recently, the fill radiator fluid warning comes on dash. I checked and it's full. Doesn't happen all the time. Like every other day. Is there a sensor or something that controls this warning that I can replace? Is there something else to look into?
Old Jul 25, 2025 | 10:50 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
There is a sensor, if sensor replacement does not correct replace fluid reservoir.
Old Jul 25, 2025 | 11:06 PM
jsconiers's Avatar
Other
Can you point me to where the sensor is? How hard is the sensor or reservoir replacement?
Old Jul 25, 2025 | 11:14 PM
VII's Avatar
VII
Connector is right on top of reservoir but now that I think about it, it might be part of the reservoir on this one.
Reservoir contains additive package that allows long coolant interval, replace with OEM or switch to 2 year interval after replacement.
Old Jul 27, 2025 | 12:26 AM
Alexie's Avatar
Likely a faulty coolant level sensor common issue. It’s in the expansion tank. Try cleaning the contacts first. If that doesn’t help, replace the sensor. Also, check for air pockets in the cooling system sometimes they trick the sensor. Cheap fix before digging deeper.
Old Jul 29, 2025 | 03:14 PM
aparksat's Avatar
w222
you sure it's completely full? It doesn't take much to set it off, just an inch below the line will do it.
the radiator cap has an o-ring that wears out, this let's fluid out over time. I had to keep filling mine every 3 weeks or so until I discovered the culprit.
Old Apr 4, 2026 | 11:39 PM
silvertonesx24's Avatar
CLS55, CL63
I have the same issue. Says it's low but it's not. What was the fix?
Old Apr 5, 2026 | 06:17 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Scan the car for codes. The wife’s W212 gave the coolant low message when the coolant level appeared fine. The problem turned out to be the thermostat. Don’t know why the error didn’t match the cause - but that’s what it was.
Old Apr 5, 2026 | 08:01 PM
jsconiers's Avatar
Other
There are two reservoirs, and they are independent of each other. Make sure both are filled. Check if you have a leak. If not its the sensor which is an easy fix. I got lucky, and it was the fact that I didn't fill both up.
