S-Class (W222) 2014-2020
Wireless adaptor for Apple CarPlay
Old Sep 5, 2025 | 03:39 PM
enj's Avatar
enj
MB S450 2018 4Matic; MB EQS SUV 450
My 2018 S450 Matic does not work iPhones with USB-C connection for CarPlay. One of the options is to use a wireless adaptors (Ottocast or similar). Has anyone in the forum had any experience or suggestions?
Thanks in advance.
Old Sep 5, 2025 | 03:57 PM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
I'm using this from Amazon and it is working very well
Wireless CarPlay Adapter for Apple iPhone (2024 Upgraded) - Multi-User Seamless Connection for Convert Wired to Wireless Car Play Adapter - No Latency from iOS 10+ to Screen w/USB C (Gray)
Old Sep 5, 2025 | 05:19 PM
NbyNW's Avatar
Veteran: Navy
Various
I bought this one. But it's still on my workbench in the garage so can't say either way if it works. Not much help, right.
Edit... it'll go into a 2020 S560. Hope it works.
Amazon Amazon
Old Sep 5, 2025 | 08:45 PM
Alexie's Avatar
Thanks in advance.
Your 2018 COMAND system only works with wired CarPlay, and it requires the old Lightning cable. It doesn't recognize a USB-C cable even with an adapter.
A wireless dongle is the easiest fix. The Ottocast U2-Air or CarlinKit 3.0 are popular, reliable choices that members here use. Just plug it into your USB port, connect your phone via Bluetooth once, and it should work automatically after that.
Old Sep 6, 2025 | 07:03 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
In my 2019, CarPlay did not recognize phone with USB-C cable and adapter. I purchased a USB-A-to-C cable, which works without problems.
Its likely something to do with the adapter.
Old Sep 6, 2025 | 04:01 PM
beechcamp's Avatar
2025 E450 All Terrain Wagon, Nautical Blue Metallic, Macchiato Beige/Black Interior
Thanks in advance.
You may have the wrong cable for USB-C. Your cable needs to be made for data + charging and if the cable is not designed to carry data, you will not get  CarPlay. Get the correct cable and you should be good to go with wired  CarPlay.
Old Sep 6, 2025 | 08:13 PM
dmatre's Avatar
USB-C cable transfers data/photos from iPhone to Windows laptop, so it must be the adapter.
Old Sep 15, 2025 | 08:45 AM
enj's Avatar
enj
thanks!
Old Sep 15, 2025 | 07:43 PM
NbyNW's Avatar
Veteran: Navy
Various
https://www.amazon.com/dp/B0FFHDRHLM...sin_title&th=1
This one worked. Pretty slick. I tried connecting my wife’s phone and think it worked too. We’ll find out when on a drive when I can play with it more, but at least one phone at a time works. Both are iPhones.
I used the USB A to the plug inside the armrest.
Old Sep 16, 2025 | 11:21 AM
enj's Avatar
enj
thanks for the info
Old Sep 18, 2025 | 08:50 AM
enj's Avatar
enj
I got this one installed, worked nicely so far.
