Five Fault Codes
I had gotten both sides of cylinder head resealed less than 1k miles ago. Today CEL came on scanned it with my scanner and stumbled on to five codes P002177, P002477, P030022, P030700, and P06DA00. Anyone have any experience with this on their W222? This is for a 2019 S560 4MATIC. I know the first two codes are related to the camshaft in bank 2. I don't notice it running any differently than normal, so if it wasn't for the CEL I wouldn't notice anything wrong. It is not running rough, no ticking noise, not misfiring or anything. Coil and spark plug was changed on cylinder 7 before the reseal and have already seen these three codes stored P030022, P030700, and P06DA00. The only new codes that I have not seen before is regarding the camshaft. I also read somewhere P06DA00 if no issues with low oil pressure they just connect a "dummy oil pump solenoid" and go about their day instead of replacing it since it is a costly repair. I have had the P06DA00 stored for about 6 months now and don't believe it is the cause for the CEL. I did clear all codes and going to be driving it a bit to see if the CEL comes back on and scan it again when it does.
