S-Class (W222) 2014-2020
Magic Wipers
Old Jan 8, 2026 | 02:10 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Magic Wipers
I have an issue where the drivers side wiper does not start flowing for about 5 seconds (Quite a long time to let them go back and forth on a dry windshield).
I had a problem where they were not spraying, and I went to change the pump but just changed the pump filter (because I was sent the wrong pump, but the old one seemed good after changing the filter and cleaning the tank.
I don't think it is a pump issue because the right wiper starts spraying by the second sweep.
Are there check valves or a diverter of some kind that might need to be cleaned or replaced.
YES, I changed the wiper blades!
Old Jan 8, 2026 | 04:15 PM
Alexie's Avatar
Common problem. Yes, there are check valves in the hose lines at each nozzle. The one for your driver's side is clogged or stuck. Find the small plastic valve in the hose leading to that side. Try cleaning it out with a pin and some vinegar, or just replace it. They're cheap and easy to swap.
Old Jan 8, 2026 | 04:32 PM
N_Jay's Avatar
I will look at the car later, but can not find a check valve that has a fitment for W222 cars.
Did not see one on the parts drawing either.
Does anyone have a part number, or are we cutting out ones built into the lines and inserting the older type?
Old Jan 9, 2026 | 05:11 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
I don't see check valves either for the magic wiper version as I have on my car. What I do see is two pumps. In the past I would assume that the 2nd pump would be for the headlight washer system, but I have no such thing on my car. If you're curious it's option code 600.
Here's the Xentry Parts diagram showing the two pumps, #20 is the Centrifugal Pump at Liquid Tank (A2318660121), #30 is Centrifugal Pump at Winshield Washer (A2318660021). Both use the #40 Formed Grommet with the screen in it (A0019987301).
If you look for a photo of part #250 Hose Line to Reservior (A2228607300) you'll see it has two lines that go to the washer fluid tank, one for each pump.
Old Jan 9, 2026 | 10:02 AM
JohnLane's Avatar
222 S-65
The second pump #may be used for washing the lens in the grill for night vision. I have not gone digging to verify.
Old Jan 9, 2026 | 11:49 AM
N_Jay's Avatar
I believe you are reading the diagram wrong.
I think there are two different (alternative) pumps.
One with a single outlet, and one with two outlets.
My cart as the single outlet, but FCPEuro sent me the wrong one.
I wonder if the check valves are non replicable due to the electrical (heaters) in the lines?
Old Jan 9, 2026 | 12:02 PM
dlafever's Avatar
I see that double outlet pump now, the Xentry Parts does show both as applicable to my car, but I have no 600 pkg ot night vision installed. I'll be updating the hoses.pumps, etc. soon so I'll let you know what I find out.
Old Jan 9, 2026 | 01:20 PM
N_Jay's Avatar
I also don't have night vision.
Are you updating the hoses to try to fix a problem? (One wiper spraying late?)
Old Jan 9, 2026 | 03:07 PM
dlafever's Avatar
Yeah I don't have a lot a time to do things twice, so when I go after it, if it's cheap I'll just do all the bits. Also, here in the desert the heat kills rubber and plastic and my car is 10 years old so it's just a little insurance.
The driver's side does have a weak delivery, which is likely mostly due to the screen in the grommet, but if it's not that I want to fix it once.
Old Jan 9, 2026 | 03:28 PM
N_Jay's Avatar
Well, I sort of figured no water WAS the pump, so went to do the pump, and found a) teh pump sent was wrong, b) the pump worked, c) the screen was clogged so changed it.
I never seven considered the hoses on a 4 year old car.
Old Jan 11, 2026 | 07:36 AM
SemperFi's Avatar
Veteran: Marine Corps
2019 AMG S 65 and too many other vehicles to list here in this small box
You are correct in that there are two different pumps.
The pump with the dual outlets is for the Magic Vision windshield system.
The pump with the single outlet is for the Night Vision camera lens.
So if your car has Magic Vision and Night Vision, you will have BOTH of the pumps installed at the bottom of the heated washer fluid reservoir.
Old Jan 11, 2026 | 09:03 AM
N_Jay's Avatar
My car has Magic vision, no night Vision, and has the single outlet pump. 2019 W222 S450
Old Jan 11, 2026 | 09:49 AM
SemperFi's Avatar
That's strange due to the Magic Vision requires two fluid circuits to operate as designed. Each wiper has dual hoses to spray only in the direction of travel.
Look close at the diagram above and you can see there are two hoses bound together (part #250) running up from the pump to the valve assembly.
Here is a partial page from WIS that shows the two separate fluid lines coming from the washer pump. I added the blue/red dashed lines to show the two circuits.
Old Jan 11, 2026 | 10:13 AM
N_Jay's Avatar
I will double check.
It was a couple of years ago when I took it apart.
I recall that FCPEuro sent me the 2 poet pump, and I had to reuse the single outlet pump.
I don't think it was the other way around.
My wipers certainly seem to spray in only one direction.
I have replaced the blades twice.
Guess I will get a chance to take a closer look in a couple of weeks, because i need to take the front end apart to fix the lower front trim.
Old Jan 11, 2026 | 10:28 AM
SemperFi's Avatar
No need to wait for disassembly, just look at the hose(s) coming up from the pump next to the fender.
If you have Magic Vision, then there will be two hoses. If you have two hoses, you have a single pump with two outlet ports to connect the hoses.
Can't have two hoses with a single outlet pump. Let us know what you find out.
Old Jan 11, 2026 | 10:44 AM
N_Jay's Avatar
Well I feel like an idiot.
I just looked looked part number for the pump FCPEuro sent me (and I returned).
the pictures from several sites show a single output.
So that means my pump has two.
Either way, I still have the problem where the left wiper does not spray till the 5th or 6th wipe.
