S-Class (W222) 2014-2020
Misfiring
Old Jan 29, 2026 | 10:04 AM
User 2226's Avatar
Misfiring
My car is misfiring from #2 and #8 , and the check engine light was on I took it to my mechanic first, he replaced the spark plug and coils on both but the car continue to misfire he then looked at the injector and replace it thinking this was the cause but no it was not , however he did notice the spark plugs had some oil on them , he could find out what the problem , so he recommend the dealership for answer , so I took it and they diagnose it with the same thing combustion misfiring of cylinder 2 and 8 has a malfunction so they replaced the coil and spark plugs on both same thing the light still on and misfiring , now they are saying its the injectors on #2 causing the issue , also resealing all injectors on the right engine bank and performing the I injector decarbonization service this will fix the problem but no guarantees , bc the misfire can return I am like why would I paid almost 4k for this services without any assurance this will fix my problem, so I am stuck and need help, I do have 120k miles on my car,
Old Jan 29, 2026 | 03:33 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
what year? moved to W221 forum for now...
Old Jan 29, 2026 | 03:41 PM
BOTUS's Avatar
S500
another cooked ECU.....
real diagnostic tool - if the dealer did it tell them to print the the thing just charged you $250 for
compression test
Old Jan 29, 2026 | 03:48 PM
Jaap's Avatar
2006 W221 S500L M273
Yeah could be a bad ECU as BOTUS said.
Old Jan 29, 2026 | 04:36 PM
User 2226's Avatar
the year is 2015
Old Jan 29, 2026 | 05:18 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Originally Posted by jaywil34
the year is 2015
Sounds like a W222.
Old Jan 29, 2026 | 05:30 PM
User 2226's Avatar
whats a w222?
Old Jan 29, 2026 | 11:49 PM
EasyPhil's Avatar
whats a w222?
A 2015 S Class
Old Jan 30, 2026 | 10:46 AM
User 2226's Avatar
just to be clear its possible it could be my ecu, that causing this?
Old Jan 30, 2026 | 11:46 AM
JohnLane's Avatar
222 S-65
OP You can help us help you by providing the YEAR and MODEL of your car.
Conspicuous by absence is any mention of a leakdown test. When cylinder(s) don't run something is missing. Spark, Fuel or compression. Sometimes a combination of the three.
ASK the dealer for a printout of the 'Quick-Test' the tech performed as a part of diagnosis.
Old Jan 30, 2026 | 12:11 PM
red996's Avatar
2013 W221 S550 2016 C217 S550
To the OP. Do you have to add oil? Do you see or smell any oil burning?
Old Jan 30, 2026 | 12:50 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
the year is 2015
moved to W222 forum...
Old Jan 30, 2026 | 02:15 PM
JohnnydoeyR230's Avatar
2004 SL55
Neither of these two places you have brought the car to are diagnosing the issue and instead are replacing what appear to be perfectly fine parts. Instead of charging you for replacement of spark plug/coil/injector they should have switched them with a working cylinders to see if misfire follows. I wouldn’t trust either of these two places moving forward.
A competent mechanic at this point would be scanning for codes, and if just misfire codes are present then scoping waveforms to be able to tell exactly what is wrong.
Old Jan 30, 2026 | 03:27 PM
MAYBACH W220's Avatar
W220
Unfortunately you have a bad head gasket if there's any oil in the combustion chamber at all you would be very lucky if the local Mercedes Benz dealership will take the job
Old Jan 30, 2026 | 05:33 PM
User 2226's Avatar
yes , I have to add oil, I don't smell any oil but yes it burns oil
Old Jan 30, 2026 | 06:35 PM
2004 SL55
There are several potential reasons for the oil consumption, which could be related to your misfire. Could be valve cover gasket, PCV, valve stem seal, Cylinder scoring/piston rings….and some more.
Simple waveforms (in-cylinder compression, ignition, cam/crank, fuel injector) from an experienced tech who knows how to use a scope and interpret will tell you what exactly is going on. Otherwise, you’re probably going to be doing a lot of individual checks along with parts changing by a less experienced shop to try to narrow down.
Old Jan 30, 2026 | 08:22 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
https://mbworld.org/forums/e-class-w...cylinders.html
Old Jan 30, 2026 | 09:26 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Well I don't know where you are but this is how the diagnostic should have gone:
1. Move coils
-no change
2. Replace relevant sparkplugs
-no change
3. Compression and leak down test
Don't put any more money into remedies without compression and leakdown results.
Old Jan 30, 2026 | 10:49 PM
User 2226's Avatar
cylinder 2 had a low compression , so that's why the dealership recommend the injectors being replace to solve the problem, I just do not think its the problem.
Old Jan 30, 2026 | 11:00 PM
VII's Avatar
VII
An injector is not going to fix a compression issue
How is the leakdown?
Old Jan 31, 2026 | 10:21 AM
JohnLane's Avatar
222 S-65
Where there is excessive leakage found in a leak down test.... Where is it leaking to? Out the crankcase? Into the cooling system? Out the exhaust? Out the intake? Or out of the incompetent techs rectum who have looked at it?
Xentry will share a lot of information with the tech. Sure seems like the Mercedes dealer should have been able to go right to it.
If they did a ‘Compression test’ How much pressure did each of the cylinders produce?
Old Jan 31, 2026 | 02:00 PM
Top Answer: 1
It's just a matter of time before the obvious is revealed. Scope the cylinder walls, the bad ones and a couple more for reference. You'll find your answer.
Old Jan 31, 2026 | 02:02 PM
VII's Avatar
VII
Yes time for a scope as well.
Old Jan 31, 2026 | 02:07 PM
W220
It's highly unlikely
Old Feb 2, 2026 | 07:11 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
It always amazes me how many good parts can be replaced with zero improvement.
Now you have the basics ignition covered already...
Can you read the FUEL TRIMS... LTFT 1 +2 .
how lean... -20?
