S-Class (W222) 2014-2020
Oil changes
Old May 28, 2026 | 11:52 AM
W205C43PFL's Avatar
Fair to say... Maybe a couple of hundreds is somewhat acceptable but if it is 1K before tax for Service A... that door rate they are charging is way too high. https://cimg4.ibsrv.net/gimg/www.mbw...7e6ec2094.jpeg
Old May 28, 2026 | 11:53 AM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Personally I want to have the proper maintenance done, I want to have that record that the A and B services were done on time, I'd rather have that from an independent than just oil changes from the dealer.
Old May 28, 2026 | 04:20 PM
W205C43PFL's Avatar
Fair stuff just make sure to shop around dealerships for best prices : ) since service A or B prices does seem to vary at different MB dealerships.
Old May 28, 2026 | 06:17 PM
SW20S's Avatar
2024 S580
Even within the same ownership chain there are differences!
Old May 28, 2026 | 06:53 PM
W205C43PFL's Avatar
I know, right?
Old May 29, 2026 | 12:02 AM
BenzV12's Avatar
W212 FL
Honestly, I have not taken to that detail but I trust in your words too. Well, let's say a chain restaurants or coffee shops for a moment . They must be serving same quality, same taste regardless of where they are including price too
Old May 29, 2026 | 01:21 AM
  #32
JohnLane's Avatar
222 S-65
Prepaid maintenance includes A and B services, you shouldn't be paying anything additionally at the dealer. If you're going to use the dealer, prepaid maintenance actually will save you some money. Of course the prepaid maintenance is over by 50k miles which is when real maintenance happens...plugs etc.
I use the dealer for the small services because its easy, I could save a couple hundred dollars taking it to my independent but I get the loaner etc at Mercedes. Big stuff, brakes, spark plugs etc I take to the independent.
MB Pre-Paid maintenance will cover whatever is due per Mercedes' maintenance schedule. Mercedes pre-paid B-Service will be fresh engine oil and filter, wiper blades, tire rotation (with non-staggered wheels/tires), brake fluid flush and inspections + reset the maintenance reminder. Your four cylinder powered car has 50,000 on it? It will get spark plugs (and filters? I forget) to go with the A service. 60,000 miles will get a transmission service to go with the B service. MB will happily sell pre-paid maintenance for much longer terms than the typical 30,000 miles. That just means the sales department made the bulk of the money rather than the service department. Pre-paid maintenance is always miles or time. Whichever comes first. Car has 500 miles on it with the cluster asking for a B-Service after two years? It gets one.
Old May 29, 2026 | 06:25 AM
  #33
W205C43PFL's Avatar
Well, you want to change the oil every year minimum regardless of mileage so there is that.
Old May 29, 2026 | 07:28 AM
  #34
BenzV12's Avatar
W212 FL
Exactly, and no need to use MB Branded Oil , it just needs to meet Mercedes-Benz's recommended specs that can be found on the label . Dealers are expensive but there's a little detail that is overlooked by me and other owners as well. It's the brand of the oil . If it's an original labeleld Mercedes-Benz oil , it's way more than expensive than generic oils .
Old May 29, 2026 | 08:11 AM
  #35
W205C43PFL's Avatar
I also recommend ether based.
Old May 29, 2026 | 09:35 AM
  #36
SW20S's Avatar
2024 S580
Sounds good to me
Old May 29, 2026 | 11:59 PM
  #37
liexpress's Avatar
2024 E450
For prepaid maintenance packages, anyone tried online shopping? My local dealership keeps reminding me of their deals: 1A+1B for ~$2200, 1A+2B for ~$3000. I heard some guys at MB dealerships had been selling cheap packages online, but just couldn't find them.
Old May 30, 2026 | 07:09 AM
  #38
W205C43PFL's Avatar
It is probably the same as extended warranties, there was a go to guy on mbworld that helps with selling these, he worked at a dealership and can be purchased regardless of which state you are in. It would probably make sense that is true for ppm as well.
Old May 30, 2026 | 08:16 AM
  #39
streborx's Avatar
Top Answer: 1
G550
That seems to be odd pricing-- do you mean "2A + 1B"?
If 2A + 1B for $3K is the offer, that makes A service $800 and B service $1400. Seems about 2x what it should cost.
Old May 30, 2026 | 10:55 AM
  #40
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Ester. Ether would be an experience…..
just putting it out there as I know, this was likely an AutoCorrect issue
Old May 30, 2026 | 11:44 AM
  #41
JohnLane's Avatar
222 S-65
LOL.... My mind read it as Ester due to context.
Old May 30, 2026 | 11:46 AM
  #42
SW20S's Avatar
2024 S580
That would be one way to go out with a bang
Old May 30, 2026 | 11:51 AM
  #43
JohnLane's Avatar
222 S-65
Does that pass for 'A Deal' in your neighborhood?
Pricing varies widely around the country... The World.
Each dealership will have their own version of an A or B service.
Pricing also varies widely based on what car. The $40.00 set of wipers for a C-Class being over $250.00 for those of us with 'Magic Vision' wipers among other things.
MB pre-paid maintenance pays dealerships the same everywhere in the country and it covers all that MB wants done in the maintenance chart. A package purchased through MB will show up in the VMI when pulled by your friendly service advisor.
Old May 30, 2026 | 11:59 AM
  #44
W205C43PFL's Avatar
Whoooops, thanks for the correction and some examples are motul xcess gen 2 (forgot if it has the mb approval needed so confirm first).
Old May 30, 2026 | 01:14 PM
  #45
Kent agent's Avatar
S600 w222
Only motul 5w40 in my s600 w222 8000km oil change
Old May 30, 2026 | 01:18 PM
  #46
SW20S's Avatar
2024 S580
My dealer is ~ $700 for an A Service, ~ $1,200 for a B service.
Old May 30, 2026 | 01:53 PM
  #47
slk3202001's Avatar
The PPM and A and B services charges are based on your Vehicle and which MB tier it falls into. For example, A class 4 cyl is tier 1 while a CLE 53 is Tier 3...so the PPM is more for a tier 3
Old May 30, 2026 | 02:13 PM
  #48
SW20S's Avatar
2024 S580
That makes sense because the larger engines have more capacity etc, but there is so much variability between dealers its crazy...and when you look at what they actually do the cost per item is astronomical. But...somebody's gotta pay for that dealer
