Fingerprint Sensor on 2023 S580
Old Dec 13, 2022 | 06:42 PM
Mbw2468%'s Avatar
S580
Can't get the fingerprint sensor to work. Starts scanning but does not complete scan and prompts to scan again or cancel. Tried various fingers but to no avail. I'm guessing it's only used for logging on to the BMUX. The dealer so far is at a loss, maybe this is new for 2023. Thanks.
Old Dec 13, 2022 | 09:57 PM
crabman's Avatar
23 S580 Executive
No; mine is a 23 and it's been flawless. I do mean flawless: I can't recall a single failure. There is a lot of stuff hidden behind that log in and I'd want to have it working. My suggestion would be to remove all users and then go through and create a new user putting in your voice, fingerprint, and if you have it, face unlock. Afterwards attempt to log in with all three and see if anything let's you in.
They all work fine for me although the fingerprint is very fast and accurate making it a better fit in my startup routine.
Old Dec 14, 2022 | 08:40 AM
Mbw2468%'s Avatar
S580
Thanks, good idea I'll try that. Mine is perfect too except for that. Fabulous car, got 28.3 MPG coming back from our 2nd home although I (mostly) keep it under 80 during the first 1,000 miles.
Old Dec 15, 2022 | 08:41 AM
Mbw2468%'s Avatar
S580
It works now. When scanning you must continuously tap your finger on the scanner, then it will complete the scan.
Old Dec 15, 2022 | 04:16 PM
crabman's Avatar
23 S580 Executive
I touch and hold for a sec; it's pretty quick for me, the hold part really is just a sec.
Old Dec 15, 2022 | 04:29 PM
Mbw2468%'s Avatar
S580
I guess I wasn't clear. That is when configuring your fingerprint for use, you must continuously tap to complete the scan process for the setup. Once setup, and to "logon", yes simply touch & hold for a sec. and that works for me too. Thanks.
Old Dec 15, 2022 | 05:57 PM
martinlarose's Avatar
2025 e 450
once your fingerprint has been inputted don’t do anything for the set up. Once you start your car after about a minute or less your preferences are installed and you are ready to go. No need to keep tapping as the car will welcome you and your settings
Old Dec 15, 2022 | 08:48 PM
DoctorDash's Avatar
I'd say the facial rec usually picks me up within a minute after leaving. The fingerprint thingy I always have to fiddle around with it for some time, its rather annoying. As far as setup no more annoying then doing it on an iphone, move around move around and eventually its done lol.
Old Dec 16, 2022 | 01:15 AM
crabman's Avatar
23 S580 Executive
Yeah, it's standard for fingerprint input; I had no idea he was talking about the setup. I'd input the same finger again as another finger if it will let you, remove the old one, whatever it takes. The main thing about waiting for face or using voice is they both take longer and I miss the toast for the last mode which means I have to disable start/stop and put it into individual manually instead of just hitting the toast. There are other things too, like having to wait for the profile to get logged into Tidal and so on.
Old Dec 25, 2022 | 11:18 AM
TSA's Avatar
TSA
S580 MAYBACH Z223
ehh the retards in ukraine didnt even register my car to the mercedes me so no user stuff for me lol
Old Jan 19, 2023 | 05:34 AM
AaronArchie's Avatar
Tesla
Thanks for the suggestion, I will try it and I hope it works. I am saving your post link for now because I want to write an essay assignment on symbolism in the yellow wallpaper moonlight the paper the bed and I already found https://thedigestonline.com/branded-...paper-the-bed/ website where I found all the information I need to write my essay assignments. When I am done with my assignments, after that I will try it.
