spotify?
which i do not have...so disappointed that it's trying to force paid model, cuz i use non-paid version thru its phone app.
was hoping it was going to be similarly seamless for spotify (for podcasts)...alas, no cigar.
bt would be a pita cuz then i'd have to handle the phone whilst driving...kinda defeats the purpose of the whole mbux/voice thing, and rather clunky ux.
For one, I miss that iHeart radio isn't one of the offerings - even though TuneIn is offered under the Radio section. iHeart was an option in my 2018 E63, but is missing in my 580. :-(
The multimedia system supports the following formats and data storage media:
Permissible file systems: FAT32, exFAT, NTFS
Permissible data storage media: USB devices, iPod®/iPhone®, MTP devices, Bluetooth® audio devices
Supported audio formats: MP3, WMA, AAC, WAV, FLAC, ALAC
Observe the following notes:
The multimedia system supports a total of up to 50,000 files.
Data storage media up to 2 TB are supported (32‑bit address space).
Due to the large variety of available music files regarding encoders, sampling rates and data transfer rates, playback cannot be guaranteed.
Due to the wide range of USB devices available on the market, playback cannot be guaranteed for all USB devices.
Copy-protected music files or DRM (Digital Rights Management) encrypted files cannot be played back.
MP3 players must support Media Transfer Protocol (MTP).
End copy/paste
Helpful hint. Rip something, put it on a drive, test it before you go further.
Lossless Listening Arrives on Spotify Premium With a Richer, More Detailed Listening Experience — Spotify
From ChatGPT
Interpretation & Trade-offs
- Max Quality Differences
- Tidal and Apple Music both support very high-resolution streaming (24-bit / 192 kHz), which is well above CD quality.
- Amazon Music also offers up to 24/192 in its Ultra HD tier.
- Spotify, by contrast, currently goes up to 24-bit but only at 44.1 kHz, which is CD sample rate.
- Bitrate Implications
- Higher bit depth and sample rate (e.g., 24/192) mean much higher data usage. For example, Amazon’s Ultra HD files are quite large.
- The average bitrates given by Amazon (850 kbps for HD, ~3,730 kbps for Ultra HD) show that Ultra HD is much more data-intensive.
- Device & Playback Constraints
- To actually benefit from hi-res (24/192), your playback chain needs to support it (DAC, wired connection, etc.). For instance, Apple notes that to stream at higher than 48 kHz on its devices, you often need an external DAC. [url alt="https://support.apple.com/en-tj/118295?utm_source=chatgpt.com"=https://support.apple.com/en-tj/118295?utm_source=chatgpt.com]Apple Support[/url]
- On mobile or under bandwidth constraints, users may choose lower “lossless” settings or even higher lossy settings to save data.
- Perceptual Difference
- For many listeners, the difference between CD-quality (16/44.1) lossless and hi-res (24/192) may not be very noticeable unless using very good gear and in a quiet listening environment.
- There are diminishing returns: higher bit depth and sample rate give more “headroom,” but not always perceptible improvement to the average listener.
Summary
- Best “theoretical max” quality: Apple Music, Tidal, and Amazon Music (all support up to 24-bit / 192 kHz).
- Lowest hi-res ceiling: Spotify (24-bit but only up to 44.1 kHz currently).
- Most data-heavy: Amazon Ultra HD and Tidal Max, depending on track.
