Turn Signal Volume
My dad drove until his early 90s. I got worried about him and bought him a fedora and said "wear this and when other motorists see it and your turn signal on they will give you plenty of room." Do I just need to buy a fedora?
And I do not remember anyone finding a way to increase it.
Admittedly, I also find the volume a little too low, particularly when I first took delivery of the car. I could hear it but I still wish it to be louder.
Now, after 1.5 years of ownership, it seems my ears are now trained for this low volume and appear to hear the blinker alright.
As far as the GLS goes my neighbor has one and when I got the S580 he came over to scope it. His first words after a brief walk-round were to the effect that the S Class is much nicer. I tend to agree but it wouldn't be neighborly to do so and I settled for saying the GLS wasn't bad, it was set up for a different duty. Which is true, the GLS is a nice car and certainly a better dog hauler than the S class. But yeah, not as luxurious for sure.
if they can’t increase the volume it would be nice if it shows on the HUD !!! How hard would it be to include it with an MBUX update?
Maybe BenzNinja can come to the rescue?
I previously had a BMW 7 and BimmerTech hacked it into HUD, and that was an MY2012.
Even though one is likely unable to change much inside the Dealer Menu, the chance of having the dealer to increase the volume is higher if such a slider exists.
(https://mbworld.org/forums/s-class-w...aler-menu.html)
I'm not suggesting hearing aid while driving but perhaps only a soft press on slight turns where the blinker auto-release may not work? Normal use at tight turns? Myself I most often use the short soft press with three blinks, perhaps not a good advice to do that.
I did not check but very likely that this volume can be adjusted with DTS Monaco but not at an MB garage with a standard Star diagnosis tool (the latter one I checked).
It wasn't but a few months ago I traded and since then the only loud noise I've been exposed to is Mrs Crab telling me my turn signal is on in this car. O_o
Regarding getting in: For every other car I've driven, I can plant my left foot parallel to the vehicle and slide my butt into the seat. For my S580, I plant my foot and then need to twist my left knee to plop backwards into the seat. It's as if the B pillar (or maybe the whole door opening) is too far forward. I didn't notice this immediately but a few weeks after delivery I noticed that my left knee hurt and figured out that it was from twisting into the car. Almost traded it back to the dealer for this specific issue.
I am driving 2024 S580 for 3 months now. The turn signal stays on without my knowledge as the blinker sound is very low. Additionally the right or left real view mirrors do not show blinking light as in many other vehicles . Very similar problem as you describe. Does any one know how to fix it ?
Combining this with ingress/egress issues, I use two automatic seating positions. #3 raises the steering wheel to max to help me enter with my two canes. I back in and pivot, then place my canes beside my left leg.
Once I start my '18 S560, I press Seat button #1, set to lower the steering wheel enough so that the turn signal green blinkers are visible in the wheel gap and can be seen. This avoids blocking the green signal enough for me. For reference, the seat is all the way down, and all the way back. I'm a fraction over 6' and at 225#.
And, yes, occasionally, but not often, I do leave the green light blinking. But, generally, this works well for me.
Good luck!
Good luck!
