MANUFAKTUR Natural Grain Walnut wood with Aluminum Lines
I know this will sound sacrilegious, but is there any way to darken that walnut wood to make it closer the anthracite color? I do not want to ruin anything, but would love to have had the darker trim, even the anthracite. This walnut is a bit light for an all-black car.
Any suggestions?
Since the wood is a veneer and the surface has the open pore look aka unevenness but is still lacquered, a proper refinish may not be easy.
Expect a few thousand to replace it, if desired. I would leave it as-is
https://mbworld.org/forums/s-class-w...wood-trim.html
apparently there's now a new variant for the Z223, called 'maybach night series', which is really just a regular Z223 with some additional blacked trims... but one of those blacked trims happen to be exactly what you are after. See the illustration below, and this video:
Since all front carbin parts for Z223 and W223 are interchangeable, you should be able to order these trims from the new maybach night series, and replace the ones in your regular s class.
Here is a flowing line kit from Germany in case that interests you: https://mercteil.com/s-class-black-p...retrofit-rZBNr
You will be able to sell your kit for good money here but I wouldn't expect any member to do a swap. There is a bit of disassembly involved; a pro should do this.
Maybach trim close-up:
