Cheap Plastic
Yeah, there’s a lot of cheap plastic. I spent a little time just pushing, prodding and moving interior trims pieces just now while I was trying to figure out a headrest/seat noise and found a surprising amount of cheap plastic everywhere. The plastic around the screens are really cheap.
When I got back into the Panamera I showed Mrs Crab the old door handle trick: You'll see salesmen do it at the Porsche dealership, they grab the interior handle for the door (not the release, the handle) and give it a stout shake while encouraging you to do the same. This is where you discover it's very solid. In any event I showed this to here and invited to try it in the S class. You don't even have to try to get the piece, that is not a handle, we're meant to hold when we open and close the door, and you immediately feel movement. Push it a little more and it will creak.
You can do that all over in this car, and nearly everything seems to have a flimsy factor to it, it moves, it squeaks, creaks, something. You don't get that in a Porsche, it's hard to sit in the drivers seat and find anything that does the same. It doesn't look as pretty but it's put together better. I just tried the same the other day and a BMW dealer and it's the same deal, it doesn't look as nice but it feels better put together.
The center console plastic below the screen is ultra flimsy and that part—which is essentially right in front of our faces and within easy reach—could have been done so much better. It should have been the same material as the dashboard imo.
In the 222 that whole seat side is part of the cushion, that cheap trim piece doesn’t exist.
Apparently the I7 kept it like our W222....
Yeah I do like how the G70 7 Series does the screen, and the interior is top notch with none of these quality issues.
I'm writing this post killing time in an antique store an hour from my house while a certain someone shops; didn't need to use the center screen once on the drive and that's typical. I'm a pathetic old man and learned to use the tech without any difficulty. You young people need to suck it up and get with the times.
To me, any MB-tex in the S-Class feels pedestrian but then the older models didn't even have that. Many surfaces were plain plastic even with Designo interiors (pre 2003)...
“pedestrian” means it’s of common quality and if you look at other cars made between 2014-2020 that were competitive to the W222, its interior is the nicest of the bunch. When you compare it to lesser cars that would classify it as “pedestrian” it’s certainly a huge step up from there. That’s not the case now, the W222 has the cheapest feeling interior in the segment and that includes the Lexus LS and Genesis G90, and exclusive Napa doesn’t solve any of that.
Its very irritating and I don't have this issue with the w222. Not sure if there's any work around. I even tried adjusting my seats to reduce the weight I put on the edge when I get out and nothing works (probably the only way is for me to lose weight!!!!)
Anybody have any workaround this?
