No S63 guys
Old Apr 17, 2006 | 05:41 PM
dbasons55's Avatar
No S63 guys
No S63 guys check this out from emercedesbenz.com
http://www.emercedesbenz.com/Images/...007Pricing.jpg
S55 kompressor will stay on for a while
Old Apr 17, 2006 | 06:29 PM
GTA7.5's Avatar
No E63 AMG either ha, it didn`t make that list either but we have the press release! That list is short. I don`t even see the CLK63.
Btw the S63 is supposed to debut in January 2007 as a 2008 model
so it wouldn`t be on a 2007 list. Time will tell us.
Old Apr 17, 2006 | 11:32 PM
HLG600's Avatar
2009 SL63 AMG
Why mess with a good thing?
Old Apr 18, 2006 | 03:33 AM
dbasons55's Avatar
sorry guys i didnt read the whole of that list it seems that i was wrong in a BIG way sorry for the wrong info
Old Apr 18, 2006 | 10:05 AM
F_Porsche's Avatar
i like to ride my bike
I am not sure if you are wrong. The list says that the 07 sclass
gets the 5.5 engine and it doesn't even mention 07 models of the eclass
clk or cls.
Old Apr 24, 2006 | 11:53 PM
Lov2xlr8's Avatar
here is a Launch Schedule for the new AMGs.
http://www.worldcarfans.com/news.cfm...aunch-schedule
Old Apr 25, 2006 | 01:27 AM
IanSL55's Avatar
'10 MB E63, '08 ML550 ('05 E55, '05 SL55, '08 E63 GONE)
Why am I not surprised?
I personally don't see the N/A 6.3 making its way into the AMG versions of the CL, SL, or S class. A TT version of the 6.3 yes, but I just don't see how MB can plan to drop that engine into a $120K+ car when the same exact power plant can be found in a ML.
~ Ian
Old Apr 26, 2006 | 08:04 AM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
~ Ian
That and the fact that at 514hp and "only" 465lb-ft of torque the cars would be slower than the old 493hp/516lb-ft cars. I suspect the S63, CL63 and eventually S63 will have 571hp and 620lb-ft of torque. Should provide a scathing performance, but those numbers mean the 5-speed auto doesn't get to retire yet!
M
Old Apr 26, 2006 | 01:13 PM
JackStraw's Avatar
2005 SL600, 2011 Honda Odyssey Touring Elite
M
There's nothing wrong with the 5-speed.
Old Apr 26, 2006 | 01:28 PM
CynCarvin32's Avatar
Mercedes Benz
its just missing 2 gears when stacked up to an M5 or 6.3L AMG. Give MB time to make the 7g work with the higher tq cars and things will be just fine.
Old Apr 26, 2006 | 03:30 PM
Wolfgang's Avatar
MBs
Great. It confirms the 2006 AMG lineup posted earlier:
https://mbworld.org/forums/showpost....5&postcount=34
But it doesn't say anything about a S63 which is not planned for 2006, but 2007.
Old Apr 26, 2006 | 03:34 PM
Wolfgang's Avatar
MBs
~ Ian
However, there's a precedent of sharing essentially the same AMG engine between S and ML: between 01-02 W220 S55 and 00-03 W163 ML55.
PS. This poster drives mostly S or ML.
Old Apr 26, 2006 | 07:12 PM
IanSL55's Avatar
The S55 wasn't supercharged?
If trademarks are a indication, look for a TT version of the 6.3 to be dubbed the 69... as in SL69, CL69, and S69...
~ Ian
Old Apr 26, 2006 | 07:33 PM
sprins's Avatar
G55, SLS, smart eq
Prior to MY 2003 they weren't. Same engine as the ML55.
Old Apr 26, 2006 | 10:18 PM
JackStraw's Avatar
You don't need 7 gears if you have the torque. The transmission in my 600 is like butter.
Old Apr 27, 2006 | 12:11 AM
Lov2xlr8's Avatar
when i was at the ny auto show this past sunday. the lady behind the counter told me that she heard the next-gen CL might have the same 55K engine as the new '07 SL.
Old Apr 27, 2006 | 01:30 PM
Ted Baldwin's Avatar
300ce
~ Ian
.........I agree that there will probably not be NA S63. However, as far as sharing engines with a less exensive car, remember that the current S65 priced at $120K shares exactly the same engine as a W211 E55 priced at $80K
Ted
Old Apr 27, 2006 | 03:02 PM
Mercedes Benz
Granted a mb 5 speed is tried and true but that does not mean a 7 speed wont offer a more dynamic feel.
Its like saying that a E55 works fine with a 2.65 rear end ratio but an SL55's 2.82 will make the E55 faster, more reponsive, and more sporty. Better gearing always makes a car respond better regardless of the amount of torque.
Yes a small V6 powered car will benefit more from a 7g transmission because it has less power to work with and it makes up for that lack of power with gearing. But give that powerful car better gearing (7g) and it to will be a quicker vehicle.
So put 7 speeds into a gearbox that can deal with the tq created by these large AMG V8k and bi-turbo 12's and the cars will be more fun to drive, shift more smoothly, have quicker downshifts, and in they end they will be better cars.
Old things work well but progression is the name of the game. Not stagnation.
Old Apr 27, 2006 | 10:10 PM
JackStraw's Avatar
I am not following you. The E55 and the SL55 use the same 5-speed transmission. They may have slightly different rear axle ratios, but any perceived difference in quickness (through curves I presume you mean) is more likely due to the 300 pound weight advantage of the E55 rather than the rear axle ratio.
I stand by my assertion that the 55K, 600 and 65 would not benefit as much from the 7 speed as the lower torque engines. If it's not broken, don't fix it.
