Sulpher smell after hard acceleration?
Old Nov 22, 2006 | 05:22 PM
peebs1's Avatar
S55 AMG '06
Anyone else have this issue? Whenever I accelerate hard, I get that rotten egg smell in the car for a few minutes. Suggestions/thoughts?
Old Nov 22, 2006 | 06:52 PM
faithful_lothario's Avatar
C280
its the devil.
Old Nov 22, 2006 | 09:27 PM
peebs1's Avatar
S55 AMG '06
Malfador in an S55?
Old Nov 23, 2006 | 07:31 PM
jparch's Avatar
2018 E63S wagon, 2016 GLE350d, GLE450 on order
change your brand of fuel
Old Nov 23, 2006 | 11:04 PM
vader's Avatar
04 E55
It's your catalytic converters doing their job....totally normal...beat on it more !
Old Nov 25, 2006 | 07:06 PM
kevine310's Avatar
Normal? I hope you don't smell it everyday!!
You have sulphur imperities in you fuel. Sulphur is a "catalytic poison". I hope you're not smelling sulphur dioxide, which is HIGHLY toxic.
try switching to a better brand of fuel. and If there are sulphur deposites in your catalytic converter, they should be flushed.
Old Nov 29, 2006 | 04:56 PM
GrepAwk's Avatar
'03 S55 (79K miles)
It's in the fuel. Change brands.
Not sure where this came from, but as a kid (40 years ago) they used to say "Pennsylvania gas" had more sulphur in it than gas from Texas or OPEC. Doubt there's any oil in Pennsylvania any more.
Who knows where the gas comes from now.
Old Dec 4, 2006 | 12:31 PM
MiamiDave's Avatar
Still looking...
Peeb's what gas are you using?
I personally recommend Chevron (top tier).
Old Dec 4, 2006 | 01:22 PM
glassJAw's Avatar
'01 E55
Every AMG will smell like that after dirving hard. It's normal.
Old Sep 3, 2008 | 12:55 AM
power-fade's Avatar
"One Man. One Engine."
Mine does that too...just need to let it burn it out by doing some normal driving.
Old Sep 3, 2008 | 02:22 AM
Murtaza's Avatar
C63S coupe, X5M
I've never smelled sulfur after hard driving
Old Sep 9, 2008 | 10:42 PM
Suprfknman's Avatar
I have smelled burned rubber after hard driving I guess it would depend on your definition of hard though
Will
Old Sep 10, 2008 | 02:07 PM
CarolinaAMG's Avatar
2015 E63 AMG S, 2006 Titan, 2008 Armada
If you had any passengers on board, tell them to tighten their ***** a little more...probably got scared. (Joke...sorry couldn't resist.)
Old Sep 11, 2008 | 11:47 AM
whoover's Avatar
'19 E63S sedan
The catalyst will spill H2S (SO2 and SO3 don't have that smell) when an engine runs rich after a period of running lean. It is quite common after a burst of high-power output.
Some areas have more sulfur in their gas than others (it's not generally something that will change markedly by brand), and higher sulfur content will of course make the smell more common.
It is a sign that the catalyst is working well. In fact, when the cat ages the smell tends to lessen. I live on a steep hill and I've noticed H2S when I get a new car home after a spirited run, but that after the car has 10,000 or 20,000 miles on it the smell is no longer produced. It's all normal catalytic converter chemistry. It also means your ECU is properly managing your A/F ratio. A little too rich is better than too lean under heavy load.
