Problems with IC pump, 65 AMG
Does the V12 biturbo use the same pump as in C32 and SLK32? I have heard that when you shut your engine off, you are supposed to hear a buzzing sound for about 20 seconds. Thats when the intercooler pump is emptying the system. If you don’t hear this buzzing sound your intercooler is out of order and needs to be replaced.
Is it like that? Because I don’t hear anything when I have shut my engine down. Does that mean that my intercooler pump is out of order?
Btw, does anyone know where the pump is located?
The 06' 65 intercooler system has a weakness which allows air pockets to form. Most likely you will have to bleed the system, which is notorious and sometimes you do need to bleed more than 5 times. The intercooler system uses 3 gallons of coolant. The pump is the same as the 55 but the 65 has two circuit instead of one combined circuit like the 55. The IC pump is located on the driver's side (bumper has to be removed) and it is nicely hidden.
I have more pictures on my other computer, i will post more tomorrow.
Cheers,
Adam
Cheers,
Adam
I look forward to the other pictures.
Thanks in advance,
Marky
Yes, only the new 07 intercooler system (S600 W221, CL600 W216) doesn't have that problem since AMG revised it.
You can bring your 65 to the dealer and have the dealer bleed the system for you.
Cheers,
Adam
Usually, we bleed it when the car goes into limp mode. Do you have any upgrades on the car?
Cheers,
Adam
My car is stock but I'm thinking about an ECU upgrade. I have also been thinking about air filters and I see that you have theese filters: https://mbworld.org/forums/sl55-amg-sl63-amg-sl65-amg-r230/197940-euroelites-bmc-air-filters-600-65-update.html
What gain can I expect from the filters only? HP numbers at the wheels and HP numbers at the crank.
In your signature it says "EuroElites software upgrade available. Free 7 days trial for 65/600/63 engines". I live in Sweden. Is it possible for me to buy a software upgrade, test it, and if I'm not satisfied I can send it back to you and get my money back?
BTW, how do I get the new software into my car? I will probably have someone to help me because my knowledge in engines could be better...
My car is stock but I'm thinking about an ECU upgrade. I have also been thinking about air filters and I see that you have theese filters: https://mbworld.org/forums/showthread.php?t=197940
You can always chat with me on skype, id name: adamgee1981, for clients out of the united states.
Yes, you can purchase the software upgrade for me, and if you dont like it, we can flash it back to stock and you will get a refund. Also, I can send you the detailed instructions on the ECU removal.
The gain on the filters will be approx 3-5 hp on the crank.
You should probably try doing couple of hot laps around the block and see if your car is losing steam.
Cheers,
Adam
Now of course if Adam was talking about a coolant leak ...
Cheers,
Adam
So when my car gets really hot I can feel a little loss of power but it's not a big differnce so I guess everything is ok with my intercooler system.
How much does the ECU upgrade cost? How much torque and power can I expect?
Marky, here's a dyno chart of the 65 we currently did.
Cheers,
Adam
