Possible w215 AMG/Sport Fogs for w220 AMG/Sport Bumper?
Thanks in advance.
w215:
w220:
shaun: are you having a seperate switch put by the existing headlight control somewhere or will the switch be integrated with the headlight control?
One is to have it run of the built in fogs but the only problem with that is both would go on at the same time.
Two would be to run a seperate switch but I think it would look a little tacky if not done right.
Three would be to take apart the headlight switch and use the rear fog light switch which I do use at all. This is the one I am I will probably do since it will be the best "oem" look.
Now to fine a battery point under the hood. Suggestions are welcomed with this one since I looked my a** of and couldn't find any. Once I am done I will post up a DIY. But idf you guys do it first please please let me know.
I'll have to figure out that bracket part though!
).I was thinking of the same thing for power. Take the driving/foglights from the headlights and run them to the lower one.
For the brackets, maybe some fabricate it with some metal brackets from home depot.
Will
Will
Will
