Brembo upgrade on S65?
Old Jan 31, 2009 | 11:59 AM
1sikbenz's Avatar
05' C230K S.S.
Any one have some spec. on the brakes of a W220 S65? - (size vs. pistons), Brembo makes a Gran Turismo brake "Upgrade", but I wonder if it's any better, the spec for those are 8 piston / 380x34 2 piece vented rotors and it says it's for the "S600", not "S65".
Old Jan 31, 2009 | 12:21 PM
Oxygen's Avatar
W220 S65 AMG
I upgraded my S600 brakes to the S65 brakes on my W220 recently so I know all the specifications.
The W220 S65 brakes are manufactured by Brembo for AMG.
The calipers are 8 piston calipers.
The rotors are 390mm (About 15.4") floating 2-piece rotors with aluminum hats.
If it says that it's for the S600 then you might need some kind of an adapter to make it work on the S65, because I had to change out some suspension components in order to fit those brakes on my car.
Old Jan 31, 2009 | 12:46 PM
1sikbenz's Avatar
05' C230K S.S.
Were the S65 units you got from Brembo significantly larger than you stock S600 ones? I guess the reason then for Brembo not having an S65 kit for their Gran Turismo line is that you're already getting them if you have the S65 and as such there is nothing to upgrade possibly? - So the stock S65 brakes are cream of the crop then?
Old Jan 31, 2009 | 02:04 PM
Oxygen's Avatar
W220 S65 AMG
Yes - for what ever reason, the US spec S600's got regular front brakes like the S430 and the S500, the rotors were only larger by a few centimeters.
Trust me if you have an S65 and want Brembo brakes, Brembo or a distributer of their brakes will gladly set you up a with a kit that will fit your car.
I don't why you would want to change them out though? I don't think that these 5000lbs cars could stop any better...
Old Jan 31, 2009 | 02:13 PM
1sikbenz's Avatar
05' C230K S.S.
Na. just a curiosity really, I'm starting to get more into the W220 S-Class, previously I focused more on the E55/63 & CLS55/63, but now I'm kinda starting to like the S-Class just as much if not more, it took me awhile to like the interior, I prefered the E & CLS class' better. By the way, I really like your car, I've been staring at pics of it at work here for days...
Old Feb 4, 2009 | 03:31 PM
cgjungdds's Avatar
Veteran: Army
08 GL450 / 08 S550 4matic
how much was that amg brake kit?
where did u get it?
wonder if it would fit 2008 s550
Old Feb 4, 2009 | 04:03 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
where did u get it?
The W221 S550 brembo it is $4,550 for either the 8 piston 380x34 or 6 piston 405x34 2 piece.
Black, Red and Silver are good to go, yellow is only available for the 6 piston
Give us a call or PM for rock bottom pricing on the kit.
Old Feb 4, 2009 | 05:01 PM
hubitubi's Avatar
s63, e55
where did u get it?
make sure your wheels also can accomodate the calipers too
Old Feb 4, 2009 | 07:09 PM
Oxygen's Avatar
W220 S65 AMG
where did u get it?
A lot - $3000+
The dealership...
Probably not...
Old Feb 8, 2009 | 02:03 PM
cgjungdds's Avatar
Veteran: Army
3000 not too bad esp for oem parts consid brembo branded are 4000+
i will ask my dealership
well i have s63 amg wheels so im not sure why it would not fit -- all other specs identical?
maybe i should just go get a s63 but i do like that i have 4matic esp in these crazy ky winters
i was driving to work the other day and on the kennedy bridge going into indiana when my rear end came around -- that was with 4wd -- lucky no one was around
Old Feb 8, 2009 | 08:12 PM
hubitubi's Avatar
s63, e55
from experience, s65 and s63 do not have the same fitment for rims.
and why would u want to replace the s65 brakes? dont think there will be much stoppage gain if any
Old Feb 12, 2009 | 11:28 AM
asg's Avatar
asg
2007 S600
I got a set of the 16" fronts and 15" rears for my S600. They are amazing. The car stops great and they look much better than the stock ones.
Old Feb 12, 2009 | 12:02 PM
V12Godspeed's Avatar
Your worst nightmare...
Pics!! Should look hot...
Old Feb 13, 2009 | 08:28 AM
asg's Avatar
asg
2007 S600
pics are here...
https://mbworld.org/forums/new-s-cla...stom-s600.html
Old Feb 21, 2009 | 07:33 PM
02S430's Avatar
W220 M113K
If it says that it's for the S600 then you might need some kind of an adapter to make it work on the S65, because I had to change out some suspension components in order to fit those brakes on my car.[/quote]
what parts did you have to change out?
