BMW 750i Put On Dyno, Actually produces close to 450 HP & 510 lb/ft torque
The S63's engine puts out 465 lb/ft of torque, and apparently this 750i's engine puts out around 510 lb/ft of torque, and the 2010 model 750 will have bimmer's new 8-speed transmission also which should improve the MPG and acceleration figures a little more! So including this new information with the availability of tuner's like Vishnu who can probably re-map the ECU on this 750i to put out probably 100 more HP and torque than what is already there.... do you guys think a chipped 750Li would convincingly beat an S63 from 0 to top speed? And what about around the corners with it's new 4-wheel steering option? Also it seems like the price for a new S63 loaded (140k?) is about what the price will be for a loaded 760Li twin-turbo V-12.... which will have almost 550 HP direct-injection engine and be easily tunable for little money too.....
Interesting comparisons to say the least......
http://www.4wheelsnews.com/2009-bmw-...the-dyno-test/
http://blogs.edmunds.com/roadtests/2...hotopanel..4.*
Interesting...
http://www.youtube.com/watch?v=R0LIau58Hdg
I guess that would make sense since the X6 xdrive 5.0 weighs quite a bit more and did it in 5.2ish
I'm glad to see BMW decided to go with forced induction engines. They are so much fun and easy to tune for big numbers.
They'll probably upgrade it a bit for the all-new 6 and 5 series cars...
As for the other question about what Benz will do with the current SOHC 3-Valve V-12 engines once the new twin-turbo V-8 comes out.... the rumours are (as I'm sure alot of you have heard many times already) that since the 550 engines will be replaced with a 5.0 liter twin-turbo DI V-8, then the uplevel 63 models will get an even larger twin-turbo V-8.... like perhaps a 6.3 liter Direct Injection twin-turbo... and an all-new Direct Injection V-12 maybe 6.0 liter or so and 48-Valves for the 600...
As for what will replace the 65 engines.... the rumours were that they might resurrect the 6.9 name again and take the all-new DI twin-turbo V-12 and let AMG do they're magic obviously on it and come out with perhaps a super AMG V-12 maybe around 6.9 liters 48-valves DOHC, etc....
A.K.A. ... the power wars are most obviously not over yet....
I mean think about it logically for just a second... if the current 550 models will basically become twin-turbo approx. close to 500 HP cars with probably 8-speed faster transmissions.... then the 63 models will have to be absolutely superior and faster in every way... and the top of the line AMG 65 models will have to be absolutely faster and better for sure then even these 63 models..... any predictions? I predict that the standard all-new 2013 model S500 with a twin-turbo DI V-8 and new transmission/software/suspension/chassis setting/newer tech will soundly beat a current generation S63/CL63.... so the next 63 and 65(or 6.9??) cars will be just insanely fast by any measure of the imagination......
Now, lets also don't forget what if BMW's M Division decides to counter with an all-out M version of this new twin-turbo DI V-12 they have.....
However,
What are they going to do to improve the traction in these monsters?
The current 65 series is practically useless in Chicago from late November through April,even on snow tires the ESP warning light is permanently set on.
I don't want just bragging rights,I want to be able to USE what I paid for.
Worry about DI motors; anecdotally, lots of bugs in latest Cayennes, 997, VW, BMW motors w/DI
65 traction/throttle response has improved significantly in MY09 iterations and winter tire tech has supposedly improved signif in past 2-3 yrs; some car nuts in Germany commute yr-round in 997GT2, using factory-spec winter tires for 5mos/yr....German weather is no worse than that of NYC or Chic (though the smoothly paved rds help much in terms of traction and safety)
From a marketing or engineering R&D standpoint, would guess vast majority of cars like 65 or 599 or GT2 are sold into fair-weather mkts like CA; and/or are used by guys in NYC or Germany or Switzerland during the 7mos/yr of semi-acceptable weather...and they can easily use some S550 4Matic or 600 (either w/winter tires) as winter beater cars on snow days and 65 (w/winter tires) on the many dry, <45F days of Fall/Winter/Spr
It is amazing what is coming down the pipe, hopefully they decide to really do an M7, that would be THE ultimate car, if they throw in a tuned version of the TT V12 that's coming, it will be insanely fast and of course handle like a dream like most M cars. And I really do like the way it looks. But with all this power, it's amazing that BMW isn't anticipating having tranny problems. They do use ZF, and Bentley uses a ZF 6 speed in the Brooklands with 774 lb. ft. of torque, no problem, so it makes me wonder why Mercedes has such problems with the strength of theirs.Btw, since turbo engines usually dyno worse, this means that even these #s for the BMW might be a little lower than actual, maybe by 15-25 hp.
