Heat Exchanger upgrade for S55
Exhaust on the AMG's are pretty good. Its all depends on the header setup on how far you go with the exhaust.
TB is a strong mod as they now offer a 80mm and 82mm. Also a vendor is working on a larger TB. Tb will help with your top end speed. also look to get 20Whp or so depending on the size TB.
Hope this helps.
I would go pulley , H/E, tune and larger tb. Then see if you want to make your car loud and shake more with headers. I stopped at 11.60 and stock exhaust..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
ive been looking everywhere for my S55 i want one ill let you know how it works out.
&& i saw a Johnson cm30 on sale for 175 shipped is that a good price for new
http://www.killerchiller.com/
will definitely upgrade oem to johnson "soon" but i just wanted to see whether or not the car would hold up to the mods like members have suggested.
right now i only have short-tube headers on my car, but will have 180mm crank pulley as well as tb in the next 2 weeks.
after that powerchip will come by and do a custom dyno tune! i will keep you guys updated with the cooling for my fellow w220's!
