Biggest rear rim / tires supported on S65
Old Dec 15, 2009 | 10:17 PM
e55 baller's Avatar
W221 S65 AMG
Question Biggest rear rim / tires supported on S65
What is the max width that can be supported w/o rubbing? 305s on 11 inch rim? 275s are the max on the E55. My S65 slides, i need more meat out back.
Old Dec 15, 2009 | 10:21 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
305`s from what I understand but will get a little rub on a big bump.. May be able to correct with custom offset.. those cars run those on 10`s but 11 may work better.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 16, 2009 | 05:22 PM
e55 baller's Avatar
W221 S65 AMG
Ok good to know, i have 275s on the stockers and they slide around and provide little traction
Old Dec 16, 2009 | 06:16 PM
COR Forged's Avatar
Former Vendor of MBWorld
Manufacturer
295/25/22 is the safest tire to run with out rub in the rear. A 22x11 is recommended as well
Old Dec 17, 2009 | 03:40 PM
e55 baller's Avatar
W221 S65 AMG
cool i think i will stick with the stock 20 inch size rims, so 295s would be best?
Old Dec 29, 2009 | 10:30 AM
COR Forged's Avatar
Manufacturer
Sorry for the long response. How wide is the factory wheel?
Old Jan 3, 2010 | 02:23 PM
BVLDARI's Avatar
GL550
While we are on the subject, can someone answer the same question for the w220? Thanks.
P.S. I am really not interested in getting anything larger than 19" considering where I live...
Old Jan 4, 2010 | 12:08 AM
Viet_Amg408's Avatar
Pinto
for 19".. you can run 19x9.5..255..
Max you can do on w220 is 19x10.. crazy stretch tires though.. like 255..
Old Jan 4, 2010 | 12:45 AM
BVLDARI's Avatar
GL550
what about in the rear?
Old Jan 4, 2010 | 01:42 AM
Pinto
that's rear...
lol
Old Jan 4, 2010 | 10:05 AM
BVLDARI's Avatar
GL550
that's rear...
lol
well, something is off in you calculations cuz I have 275/35/19 on 9.5 in rims stock there now and I know you can fit 285/35/19.
Old Jan 4, 2010 | 03:22 PM
Pinto
275" 9.5... can you take a pics..
im not caculating anything... just saying from my experienced. which i have the specs on the my car currently (lowered)..
anyways.. back to the subject.. you can go as much as 275/285 like INfamous states i guess....
My opinion the bigger the tires, make the car look ugly...just get the right recommended size.. for stock height or lowered..
Old Jan 4, 2010 | 03:31 PM
BVLDARI's Avatar
GL550
See attached pics: stock wheels and tires. front 245/40/19 rear 275/35/19
Attached Thumbnails Biggest rear rim / tires supported on S65-s65-1.jpg   Biggest rear rim / tires supported on S65-d537eec97f00000100d3ab8bf5e61f1e.jpg
Old Jan 6, 2010 | 01:02 PM
Bukwild's Avatar
2003 S600, 1988 RX-7 single turbo vert, 1998 BMW 740IL
you might have to go down to a 18' so you can get a drag radial on it. I am throwing some 285/35/18 on my 600 because I am having serious tracking issues on some eagle f1's. Unless they now make a 20' drag radial?
Old Jan 6, 2010 | 01:04 PM
BVLDARI's Avatar
GL550
I dont think I can fit 18's on mine because of the extra large brakes.
Old Jan 6, 2010 | 03:11 PM
Cali_drvr78's Avatar
clipse
I would go with 19x8.5 w/ 245 40 and 19x10 w/ 275/285 35
Old Jan 7, 2010 | 11:29 AM
COR Forged's Avatar
Manufacturer
How wide are you trying to go on the rear (rim wise) as well as in the front? Are you seeking a thick tire?
Old Jan 7, 2010 | 03:35 PM
BVLDARI's Avatar
GL550
given the power this car puts out, my interest is to put the widest possible stickiest tire for street use.
I am relatively certain i can go to 255/40/19 and 285/35/19 on the back w/o any complications on the stock rims.
The question is what other options do I have (if any).
Old Jan 8, 2010 | 07:03 AM
Zax63's Avatar
2006 s65. Ford Excursion 6.0. Pontiac GTO convertible. Porsche 944 Turbo SCCA car. Wife-E550 and 968
you only put the 18's on the back, they will clear the brakes. He was just talking about drag radials, I don't think anyone makes a good 19 drag that will fit. But you are swapping rear wheels for street use unless you want to replace your DR's a lot. And their cornering properties would be quite different from the fronts.
Old Jan 8, 2010 | 08:50 AM
BVLDARI's Avatar
GL550
oooh, forgot that you actually can run smaller diameter wheels on the back LOL. thanks for bringing that up to my attention.
Old Jan 8, 2010 | 10:09 AM
COR Forged's Avatar
Manufacturer
The options seem to stop there. The safest bet is running the 285 in the rear anything wider would run a risk of rubbing at extreme cornering and driving.18's might be the way to go
Old Jan 8, 2010 | 09:21 PM
france2112's Avatar
2015 Mercedes-Benz CLS63 AMG S
Are you sure??? First, do you know if the S65 and CL65 have same offset and fitment? I have 255/35-20 and 285/30-20 without any problems. I want to go to 295/35-20. Do you know for a fact this is a problem or is it just your thought. Appreciate any help on this matter. BTW, I own your wheels. Thanks.
Larry
Old Jan 8, 2010 | 09:36 PM
BVLDARI's Avatar
GL550
TireRack is about 90 miles away from me and as soon as there are some non snow covered days I will drive out there to have the car measured up. I will post the results once I get them.
Old Jan 9, 2010 | 08:55 PM
e55 baller's Avatar
W221 S65 AMG
thanks i will be curious as to what you hear
Old Jan 9, 2010 | 11:16 PM
Pinto
tires you have on it its over size bro..
look like monster truck lol..........
