drag radials
Old Jan 11, 2010 | 06:46 AM
Zax63's Avatar
2006 s65. Ford Excursion 6.0. Pontiac GTO convertible. Porsche 944 Turbo SCCA car. Wife-E550 and 968
drag radials
I see mickey thompson also makes an 18x35x305 drag radial. Anyone ever try one of these on a 10.5 inch 18 and see if it fits a w220? Also, has anyone found an 18" replica x 10 or 10.5 that fits our cars? Ideally, I would like it to look like the wheels were stock at first glance. It doesn't have to be gray, I'll get it powdercoated to match the fronts...
Old Jan 12, 2010 | 08:48 PM
Zax63's Avatar
I don't usually reply to myself... I'm used to the E211 subsection where every question is met with numerous answers. The update: just ordered some 18x9.5 knockoffs and I'm planning on powdercoating to match my fronts and then installing Nitto's new nt05r 285x40x18 in drag radials. If I cut some decent 60 fts I'll let you know in the spring
Old Jan 13, 2010 | 12:58 PM
BVLDARI's Avatar
GL550
post pics and results please.
Old Jan 13, 2010 | 01:37 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
I don't think too many W220s are running drag radials. I was thinking of doing something similar with my CL65 by getting knockoffs and color matching to the front ones. I couldn't find 9.5" wheels at the time. Just a heads up, the 285/40/18's are slightly taller than the stock set up (1.5%). It isn't a huge difference, but your speedo might read a little slow.
Tom
Old Jan 13, 2010 | 07:10 PM
Zax63's Avatar
Tom
Yes, having my speed read a bit low was a minor concern, but I thought it was outweighed by the importance of additional traction. And it was counterbalanced by the Blinder M47 installation.
I will post pics of the rims when I get them powdercoated and installed. I'm thinking two to three weeks. Rims shipping from the west coast (arriving 19th), then to the blaster, then to the powdercoat guy. The thing is in NH I'm not racing till at least April, so I'm not in too much of a hurry!
Old Jan 13, 2010 | 07:40 PM
320 dreamer's Avatar
2003 porsche 996 turbo
something to consider is the weight of the knockoff rims. most cheap wheels weigh in at 25 lbs. add 29 lbs for the mt and your looking at 54 lbs per side. heres another way to go. clk alloy rims in 16" weigh 13 lbs. hoosier drag radials wiegh 22 lbs thats 35 lbs per side! a reduction 19 lbs of rotational mass. thats huge! the dr's can be had in a 255/50-16 and air pressure dropped to 18 lbs. creating a huge sidewall for launches
Old Jan 13, 2010 | 10:07 PM
BVLDARI's Avatar
GL550
16" rims??? wow, what do you guys drive that you can fit 16" rims? I would be shocked if you could fit anything smaller than 18" on the back of the 65s...
Old Jan 14, 2010 | 12:14 AM
Zax63's Avatar
I'm worried about the 18's clearing the calipers, but if you say so...
Old Jan 14, 2010 | 10:29 AM
TMC M5's Avatar
+1
Not only do you have clear the brake caliper...there is a metal dust shield that needs to be cleared as well. You can take the dust shield off but doing it the "right way" requires taking the whole brake assembly off first. Depending on the offset...some 18" wheels will not clear the brake dust shield...so anything smaller will definitely not clear it.
Tom
Old Jan 14, 2010 | 02:14 PM
Flight Test's Avatar
Buick T-Type, 70 cuda, S65 and a very FAST Truck!
Does anyone know the bolt pattern dimensions? 5 by what? I was going to see if there are other wheel options just for the track. My search for 18X 9.5 inch wheels with the S65 offset is not going to well.
Old Jan 14, 2010 | 03:27 PM
TMC M5's Avatar
5X112
Tom
Old Jan 18, 2010 | 09:11 AM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
I use mickey thompson 265/40-18's and this is plently of tire if the track is prepped well. I break plenty of rear end parts so I don't think that the wider 305's are necessary. You will have some rubbing issues if you try to get fancy with the sizes.
Old Jan 18, 2010 | 03:46 PM
Zax63's Avatar
It's hard to argue with your times!
Old Feb 10, 2010 | 09:02 PM
Zax63's Avatar
update:
After being unable to find any 60et offset 18x9.5's, I am having CWWheel make me two 18x9.5 wheels with a 55et offset, I'm hoping that will allow me to run 285 DR's, but we'll see when the rims get here. Should be two weeks or so for delivery, and I will post results, be they positive or negative.
