Undertray cooling ducts,one or two?
Old Apr 7, 2011 | 02:00 PM
Flight Test's Avatar
Buick T-Type, 70 cuda, S65 and a very FAST Truck!
I was changing the oil yesterday on my 2006 S65 and noticed one of the tubes on the undertray was missing. As a reality check does everyone out there have both tubes attached to the undertray, or just one?
I believe they are used to provide cooling air to the tubine housings.
To be a bit more specific, the part in question is attached to the flat undertray that you have to take off to get to the oil pan under the car. When you remove it there is one long plastic tube that goes up near the turbine housing. From the bottom of the car you will see tho NACA ducts on the tray and they attach to that. I think there used to be two but I can't remember.
Anyone know if they should both be there? Only the driver side was still there.
Old Apr 7, 2011 | 03:02 PM
Oxygen's Avatar
W220 S65 AMG
Yes there should be 2 ducts. I've taken that panel off many times and there is supposed to be 2 there.
Old Apr 7, 2011 | 04:15 PM
Hmmm... I wonder if the dealership took it off and did not replace it?? I guess I will need to see if I can find another one. I will look on STAR to see if I can find the diagram to show them when I try to order one.
Thanks for the info!
Old Apr 7, 2011 | 05:16 PM
mrbenzes's Avatar
2005 S55, 2002 E430, 2007 CLK350, 2006 SL55, 2003 SL55
My S55 also has two ducts, I think they also cool something else under there as mine lacks the turbos.
Mike
Old Apr 8, 2011 | 08:02 AM
Interesting, I guess I need to look at exactly where they go. Any ideas?
Old Apr 8, 2011 | 11:18 AM
mrbenzes's Avatar
Here is a pic of the S55 setup..hope this helps:
Mike
Old Apr 8, 2011 | 11:33 AM
Thanks for the picture! I wonder if I can order just one side? I will have to see if I can track down a part number.
Did it have a reference to the #3 item in your picture to as what it is called?
Thanks again.
Old Apr 8, 2011 | 11:37 AM
mrbenzes's Avatar
It didnt have any reference other than "Cooling tubes". Probably a dealer part only for sure..just for grins, did you check farther back on the other covers? Maybe it just became dislodged while friving and has moved its way back and is sitting in one of the other covers by the tranny, etc.
I had my lower cover off a few months back for a transmission fluid change and remember that they arent very substantial and just kind of sit on the lower cover.
Mike
Old Apr 8, 2011 | 11:48 AM
Good idea, I will check under there.
