Bought a used S63 and regretting it... CEL, Seats Broken..
The seat adjustments don't work as there appears to be something wrong with the inflate/deflate. For example if I inflate the top-sides it seems to unevenly inflate the cushions right/left and then eventually a few mins later it deflates automatically. Similar things to the rest of the top adjustments. Bottom (side bolsters) seem to be fine.
MaxiDas picks it up as:
1. 9200 - The module carrier for the backrest is defective
2. 9220 - It is not possible to inflate an air cushion in the backrest
As if that wasn't enough the check engine light went on within 7 miles of leaving the lot.
* 0745 - Self-adaption of mixture formulation for enrichment at idle for the right cylinder bank is above the permissible limit (P2187)
* Generic OBD tools pulls it as a P0170 fuel trim (bank 1)
Then I realize that the tires they have on the car are mismatched -- and the front tires are Federal SuperSteel 585 with a 93W load rating which seems a bit low for the car?
And when I drive over a bump with the passenger rear tire anything above 35 miles per hour the car wiggles/jumps a bit. Maybe it has something to do with the rear tires being relatively worn? What confuses me is why it happens just on the passenger rear. Hard to describe.
This is my first used car experience, and I am really regretting it.
This is also my first MB and no idea of what will happen if I goto the dealership... I did buy the extended warranty but suspect if I bring it in so soon after buying it, its likely to be flagged as some sort of existing issue?
Searching through the forums I see the 0745 is not uncommon. Not seeing much on seat issues or what possible driving over a bump with the rear wheel could possible be doing.
Anyone got a good place to recommend in Chicago? Is taking it to a dealer going to flag the car vehicle history report with the issues?
-Adam
I assure you I'm not hitting the buttons. The adjustments are done via the Command system so there is a visual representation of what the Command system thinks the inflation level is at, which is different from the actual lumbar inflation. Having read the manual and played with the settings for hours, combined with the fault codes I'm pretty sure its not user error.
BP and Shell Premium (93 Octane I believe) so I don't think gas is the problem.
-Adam
Sounds like the car hasn't been well cared for. Luckily, it's an S-Class and can be rehabilitated if it wasn't abused for too long. They tend to be pretty tank like, given how much Mercedes has riding on them. But that rehab process won't be cheap. Run all the cheap fuel out (preferably on a road trip), run some fuel system cleaner through it (I recommend BG), then swap out the fuel filter and "go forth and sin no more." That should remedy the fuel issue. I did it on my 55, and it changed everything in a way only I can tell. Also have the dealer reset the engine and trans computers so the car can learn your driving style.
Makes sense. I put some fuel cleaner in it, and it cleared the CEL I think (its possible the OBD scanner cleared it too). It came on again after another tank of gas without any cleaner -- so will try it again to see if it helps.
The warranty is 3rd party -- GMAC. MB dealership I called seemed familiar enough with it - but don't have the paperwork yet to even know for sure what it covers. The dealer marketing material of course makes it look like they cover everything so we'll see.
Ordered some Hankook Ventus V12 on TireRack -- pricing is good. Be interesting to see how they work.
I was shocked to see the dealership offer a courtesy vehicle.
Thanks for all the help!
Thanks,
Adam
and an additional
*2091 - The mixture in the right cylinder bank is too lean when idling (P2187)
The dealer's recommendation is to replace the entire intake manifold because of a leak somewhere which I don't agree with. Because I can't get them to isolate the leak how do we know replacing the manifold will solve the problem.
Any thoughts from anyone who has had similar issues?
Most of the used cars out there are full of 80% fault codes but mostly from the past if you run a full scan.
