W220 S55 AMG Catless Straightpipe
Rating: Thread Rating: 5 votes, 5.00 average.
Old Oct 18, 2012 | 05:07 PM
Viet_Amg408's Avatar
Pinto
Everything is straight pipe (Catless) from stock Header back except Stock AMG Muffler...O2 Non-fouler spacers..
Really quite driving around town, very Crispy and Loud 2.5k-4k Rpm...
Old Oct 18, 2012 | 06:40 PM
02Drunkenup's Avatar
335i
nice... how much did it cost you?
Old Oct 19, 2012 | 03:44 AM
SnoopSER's Avatar
Your Mom Krazy
Sounds good....will it pass smog?
Old Oct 19, 2012 | 04:09 PM
Pinto
i did this section at a time,
remove rear resonator = 100
remove 2nd cat $150
remove primary (1st) cat $100..
roughly through out 2 years....
but anyone consider do this at one time is much less..
i would say somewhere $200-300 labor
Old Oct 19, 2012 | 05:18 PM
Pinto
yes it will pass smog, because i have o2 fouler installed. (cat fooler_ hahhahah)
I do this because the new Cali Smog law tailpipe sniff test eliminated on 2000 model and newer cars, trucks, vans, and SUVs. starting Jan 1 2013..
http://www.smogtips.com/new-smog-law-AB-2289.cfm
as long it pass all the ID test on-board computer.. the rest is inspection only.. (make sure you know the smog test guy)
Note: stock header 2.5 to 3" pipe..
http://www.flickr.com/photos/87397461@N05/8103584992/http://www.flickr.com/photos/87397461@N05/8103584992/ by http://www.flickr.com/people/87397461@N05/, on Flickr
Old Oct 22, 2012 | 12:00 PM
Busta Riles's Avatar
1969 280S, 1991 300E
That sounds amazing!
Forgive me...we we don't have emissions/smog testing up here...Do i need to do anything other than just eliminate cats/res and install str8 pipe?
I am referring to this comment:
"as long it pass all the ID test on-board computer.. the rest is inspection only.. (make sure you know the smog test guy)"
Are you talking about the car's cpu or the smog tester's cpu???
Old Oct 22, 2012 | 01:19 PM
Pinto
smog read off car "CPU".. ID Test.. is onboard emmission test to make sure its operation..
you don't need to do anything like i state above post.. just contact your muffler guy, see if they able to do it..make sure they experienced before cutting off your piping...
cutting and welding the primary cat is lil bit challenging because there's lil room next to the vehicle's firewall.. as you can see with the pics above post
Old Oct 22, 2012 | 01:48 PM
How was the sound after you did the resonator & secondary cat?
Did removing the primary cat make a huge difference?
Old Oct 22, 2012 | 02:16 PM
Pinto
2nd cat/ resonator is ok...sound good..
1st cat remove, deffinatly feel less back-pressure and better flow high-rpm.. SOUND ALOT LOUDER, UNDERLOAD... THE AMG REAR MUFFLER DOES A GOOD JOB RESONATING THE EXHAUST SOUND UNTIL YOU OPEN THROTTLE ..
IF YOU DON'T MIND THE SMELL DO THE 1ST CAT... TOO..
Old Oct 23, 2012 | 09:50 AM
ItsAdam1's Avatar
04 S55 AMG
damn that sounds soooo good, I've deleted my resonators and have been debating on removing the secondary cats. I guess now I need to remove both!!
Old Oct 24, 2012 | 04:53 PM
hotgreek's Avatar
2004 S 55 AMG
where do we find the o2 fouler ?
Old Oct 24, 2012 | 06:45 PM
Pinto
WHERE ELSE.. EBAY..
OR YOU CAN BUY IT AUTO PART STORE.. LOOK UP ONLINE FORUMS ABOUT THE PART NUMBER, BUT YOU HAVE TO DRILL OUT THE O2 FOULER URSELF.
BUY THE ONE ON EBAY, ITS PREDRILL, SO YOU CAN FIT O2 SENSOR IN IT..
CATLESS- ONE LONG ONE SHORT ONE....
IF YOU ONLY HAVE 1, IT WILL STILL THROUGH THE CODE.
Old Oct 25, 2012 | 08:19 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Sounds great! I run the same set up and also pass the same smog test. I have large custom long tues and 3" all the way back to stock mufflers.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 31, 2012 | 03:00 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Would love to hear a WOT video
Old Oct 31, 2012 | 01:37 PM
Pinto
ok, i will strap my gopro rear bumper and make a video soon..
Old Nov 1, 2012 | 04:02 PM
chawkins2001's Avatar
2006 E55 AMG
Sounds raw
Old Nov 1, 2012 | 07:51 PM
OCKlasse's Avatar
MBworld Guru
Old Feb 14, 2013 | 02:15 PM
Diesel117's Avatar
Ford F250 CC Harley Davidson (stolen), Porsche 911 996, SL55 AMG, Ducati 996S
Cannot view the video. It is no longer on youtube. Can you re-post it?
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
