?'s for Trans fluid swap
Old Jan 2, 2013 | 07:52 PM
richvegas's Avatar
2016 S65 AMG coupe, 2010 E63, 2015 Z06/z07 m7 vert 735rwhp, 2000 f-350 crewcab w/ 16" kelderman kit
I'm going to do a fluid/filter/conductor plate/connector change on my S65 and had some questions
-Which fluid? i searched and it seems there are different MB fluids
-Do i need the SDS to flash or load anything with the conductor plate swap?
-any other tips as well
thanks guys!
Old Jan 3, 2013 | 08:13 AM
mrbenzes's Avatar
2005 S55, 2002 E430, 2007 CLK350, 2006 SL55, 2003 SL55
pentosin CH11S is the fluid to use, pln on replacing the leaking electrical connection ($20) and you will not need STAR or SDS or DAS for anything on a trany flush...You may need to purchase a shop dipstick to verify you have the same amount of fluid that was removed...check the level before (old fluid) and after a few das of driving. You will not be able to drain the torque converter...there is no drain there.
Drain/fill/drive/drain/fill until you consume about 10 Liters of the fluid.
Old Jan 3, 2013 | 10:13 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Use MB transmission fluid.
Pentosin CH11S is the fluid used for the ABC system not transmission.
Old Jan 3, 2013 | 10:37 AM
mrbenzes's Avatar
Whoa, he right!..Im reading too many threads at the same time...go to EBAY and buy the MB approved transmission fluid..it will be cheaper there.
Mike
Old Jan 3, 2013 | 01:32 PM
richvegas's Avatar
i thought i was reading that wrong. lol
i have seen the mb fluid on ebay and saw different kinds, is one better?
for the flush, i was going to do the "disconnect the cooler line" technique as i'm going to do the radiator change at the same time.
its gonna be a long day in the garage:
-oil and filter change
-cabin filters
-air filters
-trans service with conductor plate and connector
-radiator swap
figure i'm saving myself like $1k in labor
Old Jan 3, 2013 | 02:12 PM
mrbenzes's Avatar
if you have some type of pump to flush the fluid with you will probably be doing a better job than dropping the pan...what about the AT filter in the pan?
A dealer AT flush is over $400..I checked prior to doing mine.
I think you need the MB tranny fluid for the 722 type transmissions, but I am unsure...the threads on this board will state the correct transmission for these AMG cars.
Old Jan 3, 2013 | 02:54 PM
richvegas's Avatar
I'm going to replace the filter too.
Should be a fun all day experience
Old Jan 4, 2013 | 12:32 PM
Quadcammer's Avatar
96 and 08 911 turbos
there is a lot of fuss over the tranny fluid.
in my opinion, you are fine with a 236.10 or 236.14 MB spec fluid, of which there are a few.
Old Jan 29, 2013 | 01:07 PM
jnash's Avatar
2017 S63
Shell 134
Mobil 134
Valvoline +4
Valvoline maxlife dex/merc are all approved
I use Shell 134 in my 2003 S55 AMG
