weird noise from trunk in 2006 S55
Old Apr 22, 2013 | 01:42 AM
Eric_pcars's Avatar
Mercedes s55 amg
When i pop my trunk I hear something sounding like a small electric motor,it lasts for about 10-20 seconds and then it stops! Nothing is on in the car,so what could this be!
Old Apr 22, 2013 | 08:11 AM
mrbenzes's Avatar
2005 S55, 2002 E430, 2007 CLK350, 2006 SL55, 2003 SL55
That sounds normal to me....mine does the same thiing..im pretty sure that is the standard routine for the power trunk actuator.
Mike
Old Apr 22, 2013 | 09:35 AM
Eric_pcars's Avatar
Mercedes s55 amg
mine doesnt have power trunk
Old Apr 22, 2013 | 09:43 AM
mrbenzes's Avatar
Oh, OK then it may be the air pump making noise...I dont think I would worry too much about that unless you begin having battery discharge problems.
Mike
Old Apr 22, 2013 | 01:37 PM
Quadcammer's Avatar
96 and 08 911 turbos
I have it too, for the past 5 years. Causes no problems with the battery and you can only really hear it with the car not running. I've stopped worrying.
Old Mar 13, 2014 | 12:28 AM
Amaterasu's Avatar
G63 2019
Guys on my 2012 w221 550 new 4000 km same issue! And about two weeks its start, I come to service they check all system and electrick moror and say that dont see anything, say something about air, its really ok? I start worrying and think maybe come to service again, car absoulutley new!
Old Mar 13, 2014 | 09:46 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Mike
The S class does not have an air pump for the suspension, as we have ABC hydraulic system. Mine makes a winding noise when it closes and sucks down but I have the auto-open and close motor.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
