WHEELS OFFSET HELP
Old May 22, 2013 | 09:17 PM
hotgreek's Avatar
2004 S 55 AMG
WHEELS OFFSET HELP
Can someone tell me the offset for a 2004 S55 ? I'm trying to buy wheels for my car and I can't find anything to fit on . In old post someone told me the offset is 44 front and 46 rear but no one makes wheels with this offset except if it's custom made and then we talking big $$$$$$$
Any can help
Thank you
Old May 22, 2013 | 09:33 PM
ozaudioman's Avatar
2004 S55 AMG
Any can help
Thank you
I had the exact same problem a few months back. I eventually fit a set on, with a an 08 set from a E I believe, with a much different offset than advertised. I'm positive the front is 44 but I'm not sure what back is. I'd go to a wheel place and have them check for you...I was surprised but 35 offset fit mine with no problems and no fabrication/spacers whatsoever.
Old May 23, 2013 | 06:20 PM
hotgreek's Avatar
2004 S 55 AMG
I have Mandrus Mennheim on with 35 offset but they rubbing in the rear fender. No all the time but when I go over 45 mph ....And we talking New York roads ..*(&^^^&%7&%&^%
Old May 23, 2013 | 06:49 PM
grane's Avatar
GLK350, SL63 AMG
mandrus
Search on the MBUSA website for your OM if you don't have one. The wheel offset is listed. I'd guess around 44. 35 will rub.
Mandrus are notorious for claiming they have the correct fitment of AMGs "universal" but they rub. I tried a set for winter tires and they rubbed. They took them back. They had 35mm offset.
I'd go with AMG wheels and be done with it.
Old May 23, 2013 | 07:25 PM
JDoggery's Avatar
Designo AMG
Many of the Mercedes tuners will make wheels that are designed to fit. Otherwise you can run spacers to adjust the offset.
Old May 24, 2013 | 03:57 PM
Craftysince86's Avatar
W211
have you tried running smaller tires?
Old Jun 22, 2013 | 05:24 PM
N Pee AMGee's Avatar
03 S55 AMG, 01 740i (T-boned), 97 Saab 9000 CSE daily driver
I got a set of Eurosport wheels, 19"x8.5 fr - 32 offset, & 19"x9.5 rr -35 offset. Can anyone tell me what size spacers to use and should i try 255/40 fr, 275/35 rears??
Old Jun 22, 2013 | 05:30 PM
Triman2008's Avatar
S55 AMG
I have a Vossen CV3's 20x8.5 +32 in the front, and 20x10.5 +35 out back with 255/30 and 285/25 and they don't rub any more since I rolled my fenders. The clearance in the rear with the caliper is maybe 5-6mm with no spacer. If you don't go with a wide rear you should be okay. Maybe a 10" rear but that would be about maxed out.
Old Jun 23, 2013 | 01:19 PM
ok, thanks Triman2008. I hv another newbie question....what does "rolling the fenders' mean?
Old Jun 26, 2013 | 09:24 AM
Triman2008's Avatar
S55 AMG
If you feel on the inside of the fender, there is the sheet metal from the fender that sticks straight out......rolling the fender pushes that metal up in to the fenderwell, giving you another 1/4" of clearance to run a bigger tire. I have a fender roll and it was worth the $250 to buy it.
Old Jun 27, 2013 | 09:17 PM
hotgreek's Avatar
2004 S 55 AMG
yah I did that already to roll the fenders but not luck . I think rubs in the bumper
Old Jun 30, 2013 | 07:04 PM
Oh ok thanks again
Old Jun 30, 2013 | 08:01 PM
so i'm running 255/40/19's in the front, and 275/35/19 rear, and i had to use a 10mm spacer for these wheels in the rear. It rubs over large dips on the NY/Northeast region highways (our roads are )
Old Jul 1, 2013 | 06:14 PM
hotgreek's Avatar
2004 S 55 AMG
I try those wheels and I send them back I had the same problem I live in NY tri state area too
After a year and a half research on wheels I find out that those cars S55 AMG's to get the right rim its got to be CUSTOM MADE .That means big $$$$$...around 5k
Old Jul 1, 2013 | 07:03 PM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
Never mind, wrong forum, sorry.
