ABC leaking struts again
I have seen a lot of threads on this issue, but I need some advice. I have a 2001 s55 AMG and the left front strut leaks and drops down after about 20 minutes. However, as soon as I start the engine and put it in gear it pops right back up. Before I start taking apart the front end or before buying new strut, is there anything I should look for? Where could the leak be and if I find the leak, can it be repaired? Just looking for a way out besides buying new struts!
Good luck
What's more likely is degraded or contaminated seals in the front valve block. Read this thread (or several others) to see how to service the valve block:
https://mbworld.org/forums/s-class-w...03-s600-8.html
Nick
